I got a b lift!!!!! help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-30-2001, 08:38 PM
Well my dad just went and bought a brand new 4 door f-150(no he has not seen the light yet in samuruis but hey if I could afford it then I would buy it too!!LOL) he had this body lift kit for a supercab so if it wont work then I will take 10 of the 16 lift mounts it comes with and attempt to put it in throughout the weekend! either that or I will go with the boat rollers! thing is I need someone to tell me all the things I need to know just to sort make sure I got everything down!
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
72 fj40/crate 350/33's/discs
post #2 of (permalink) Old 08-30-2001, 11:37 PM
I Do This For The Glory
JEEPN's Avatar
Re: I got a b lift!!!!! help!
You WILL need the stud extensions, they are a PITA to find and expensive when you do find them.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #3 of (permalink) Old 08-30-2001, 11:47 PM
Nowhere's Avatar
What size is the lift for the ford? I wonder if ACE has the right length of bolts to use... hmmmmm
I'm LOCKED!
Got zook?I do,88.5 spoa'd on 29'shttp://www.geocities.com/bik3r
Nowhere is offline
post #4 of (permalink) Old 08-31-2001, 08:08 AM
If it's more than 2" you'll need a fuel filler hose. Its a real simple operation: Remove all 10 bolts from mounts, disconnect distibutor leads from harness, then lift the drivers side with a floor jack. Insert 5 bushings and washers along drivers side. Lower jack, rinse and repeat along passengers side. Bolt on all mounts, re-connect distributor, install new fuel filler hose.
You can also take the opportunity while you have the passenger side lifted with the jack to check all your hoses coming out of the fuel tank on top, make sure none are cracked, missing, or disconnected. Easy way to get water and crap in the fuel tank. I noticed one of the breather hoses to the cannister was broken and left the tank open to the elements, so now I know there is about 5 lbs of east Texas red dust in the tank from Barnwell and another 5 lbs of mud from the last mud hole I conquered. Doesn't leave much room for fuel. [img]/wwwthreads_images/icons/smile.gif[/img]
Good luck bro! Do you still want these shafts and front axle????
Neal the Zukiguy
88.5 Weber carb, header, 4.16 t-case, 31x10.5 M/T's, 2" s/r, 2 1/2" bod lift, front tube, Swift seats, on-board air
post #5 of (permalink) Old 08-31-2001, 10:08 AM
JEEPN's Avatar
Make sure the body lift will accomodate the stud nut extensions. If it won't, it won't fit on without some issues.
JEEPN
JEEPN is offline
post #6 of (permalink) Old 09-01-2001, 08:27 AM
I had been messing around lookin at the bolts and what not and it turns out they are to long!! I do not know how long ford needs them to be but these are a good 10"es plus!
P.S. yah I will still take them if you would be willin but what I am startin to worry about is getting them to me cause I do not get my liscence until oct 13th!
Thanx
Studly
