Dana 44 swap...?
Ok, I need the details of the Dana 44 swap. Aren't you supposed to use the axles out of an '78 or '79 wagoneer? Why these years? What make them different that other years? I hear any full size wagoneer totes 44's. Also, what's involved in using the brake apparatus them? Should you swap back to the samurai brakes? Of stick with whatever beefier equipment is on the dana's? Wouldn't this change your rim size? Any info would help, thanks,
Pillard
'87 Sami, 5.5" SpOA, 33" Pro-Comps, Snorkel, 8k winch, 23" buggy-leafs, Cal 4.16 t-case, Lkd Frt, welded rear, 8-point Roll Cage, etc, etc.
