Scary Wobble. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-30-2001, 08:36 AM
Scary Wobble.
Hey folks,
I've finally finished my rig...YIPPPEEEEeeeee
but there's a problem.
when I get to about 45-55km/h (not miles) I get this very very very very scary wobble in the front end. If I go faster it evens itself out,b ut when I slow down to that speed again I get the wobble, then it goes away once I'm below 45-55km/h.
I have gone 3" springs and 32" MT's
any ideas as to what should be checked first?
'85 SuziSkip
Slowly building a beast.
Need some custom graphic/new media design done?
Visit http://www.newflavour.com today!
post #2 of (permalink) Old 08-30-2001, 08:50 AM
I Do This For The Glory
JEEPN's Avatar
Re: Scary Wobble.
Tires, definitely the tires. Mine does the same thing with the Swampers, but they're not balanced as they're bias ply. When I put the Rikens on (street tires), there is no wobble.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #3 of (permalink) Old 08-30-2001, 08:51 AM
mike shannon
Re: Scary Wobble.
tire balance, front end ball joints, wheel bearings, steering stabilizer and if that all is ok add a steering stabilizer to the axle. and that should do it unless you have a bent rim or bad cupped tires. later mike
zuks and toys
post #4 of (permalink) Old 08-30-2001, 08:55 AM
Re: Scary Wobble.
I had a similiar problem that turned out to be too much ROAD FORCE they called it. Discount tire has a special machine that will find the heaviest part in the rim and the heavies part in the tire. If they are too close to each other, when mounted, the tire will never be balanced quite right. They checked mine for free since i bought my wheels through them. One tire was at 35 pounds of RF , and 30 is the maximum it should be. (so i've been told) They got it down to 22 pounds of RF.
-Ryan
'88 Sami. Moderately modified. Two track mind
[email protected]
ZuksRule is offline
post #5 of (permalink) Old 08-30-2001, 10:04 AM
Re: Scary Wobble.
definately check out the front end and tires/wheels, but it also maybe as simple as taking out the play in the steering box. Do a search on this BBS. There was a lengthy discussion and I posted how to do the adjustment as did other members.
-Farther
Farther is offline
post #6 of (permalink) Old 08-30-2001, 12:04 PM
Nowhere's Avatar
Re: Scary Wobble.
Yes! check your steering box. Like I posted earlier, talke lots of air out of the tires so they are a pain in the arse to turn, now gently turn the steering wheel back and forth and look @ the wheels. If the play is greater than like 5~10 degres, you need to adjust the box. I could rotate mine about 1/4 way before I did the adjust. IT REALLLLLLLLY helps! I also added a MUCH larger steering stabalizer/dampener/shock/round-thing-that-makes-steering-nice hehehe.. By far, best improvement was: Change the little rubber seals on the knuckles, adjust the adjuster (whoops) on the steering gear box, and add a larger steering dampener.. I'll post the right part number for a real good one!
I'm LOCKED!
Got zook?I do,88.5 spoa'd on 29'shttp://www.geocities.com/bik3r
Nowhere is offline
post #7 of (permalink) Old 08-30-2001, 03:35 PM
Alfie
Re: Scary Wobble.
I get it a little too, still tryin to track it down. Done balancing and steering damper, etc. beginning to suspect toe in and castor. I haven't shimmed the front spring plates yet.
Alfie.
post #8 of (permalink) Old 08-30-2001, 04:51 PM
ackerdackerly's Avatar
Re: Scary Wobble.
Don't forget to get tires balanced with weights on both sides of the rim (if neccessary)! I discovered that balancing axially (what everyone thinks balancing is about) AND balancing at right angles to the spindle shaft with weights on both sides of the wheel is very important!
Wheels look nice with no weights showing, but the overall balance could really be out because of it.
Ackerdackerly and
'Ol Yellow Wheels before...
ackerdackerly is offline
post #9 of (permalink) Old 08-30-2001, 07:55 PM
Re: Scary Wobble.
Thanks heaps guys,
I'll take her for a wheel alignment and balance as soon as I get a chance. If it persists I will look at the stabiliser and I will look into the steering box free-play ASAP.
again thanks heaps.
'85 SuziSkip
