engine break-in - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-26-2001, 09:12 AM
engine break-in
just finished my rebuild (2 people 12 hours) i keep getting different suggestions for a break-in period, what's best for my zook?
post #2 of (permalink) Old 08-26-2001, 05:40 PM
ackerdackerly's Avatar
Re: engine break-in
Well, I just rebuilt mine and I ran what the manual said to run in the engine changing it and the filter at 300, 600 and finally 2500 miles.
I drove mostly on the Interstate back and forth to work (13) miles -- along with about 30 miles at the 2001 Melt -- keeping it under 3800 RPM.
I switched to 89 octane because of the compression gain (cylinders bored out to +.40) and am now getting 24MPG.
Hope this helps...
Ackerdackerly and
'Ol Yellow Wheels before...
ackerdackerly is offline
post #3 of (permalink) Old 08-26-2001, 07:47 PM
zooky's Avatar
Re: engine break-in
did you break it in with synthetic oil?
zooky is offline
post #4 of (permalink) Old 08-26-2001, 08:02 PM
Re: engine break-in
holy crap ack 24MPG!!! a stock zuk has like 3? to begin with doesn' it??!!
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
72 fj40/crate 350/33's/discs
post #5 of (permalink) Old 08-26-2001, 08:47 PM
zukiman
Re: engine break-in
Don't break your motor in on synthetic! It'll take it forever to break in. You want the bearings and rings to seat quickly so that your engine will be up to full compression and stop burning oil more quickly (especially if you rebuilt it with the hard chrome rings).
When I rebuilt my motor, I used the cheapest, thinnest 10W-30 I could find, and I changed it frequently. When you first start up the motor, let it idle for a couple minutes. Then start bringing the idle speed up and down....not racing the motor, but allowing the rings to begin to seat at the entire rpm range.
Then take it out for a gentle drive, constantly varying the engine speed. The best thing to do is put it in 3rd gear, and accelerate from 1000rpm to increasingly higher engine speeds, then coasting back down to 1000 while in gear. Do this from 1000-3000-1000, then 1000-3500-1000, then 1000-4000.....do that as many times as you can, then after the first 50 miles, change the oil.
Gradually bring your rpms up higher and higher as you do the acceleration/deceleration runs, eventually going all the way up to redline. Be sure to keep an eye on your engine temp, and check your oil/coolant clarity for any gasket leaks.
In the first 500 miles, don't do any steady-speed driving...constantly vary the speed of your engine. Row through the gears in town, using the entire range of rpm's you intend to use once the motor is fully broken in. Change the oil again at 500 miles, 2000 miles, and then the usual 3000-mile intervals. You probably won't switch to synthetic until at least 10,000 miles. I tried that, but I burnt through the oil so quickly (in part because of my hard chrome rings taking forever to seat, and my high-pressure GTi oil pump) that I switched back to conventional oil, and at 15,000 miles I'm still using it. Once it stops going through oil, I'll switch back to synthetic.
Fuel economy, I can't speak for. I drive that motor really hard though, because it's like a race car. It sounds cool and boy does that GTi motor pull hard! I can do over 85mph too, but that burns a LOT of gas. I get about 17mpg in my big Samurai with its GTi motor and big ol' Swampers. But my daily driver samurai has returned 32mpg in mixed city/highway driving since I don't have to get into the throttle very much to push through the wind and get the tires rotating.
Good luck!
-- Geoff Beasley
post #6 of (permalink) Old 08-26-2001, 08:53 PM
zooky's Avatar
Re: engine break-in
sorry, bad joke. There was a thread about break-in oils a few weeks ago. 17MPG isnt so bad, I get less then that with my 1.6
zooky is offline
post #7 of (permalink) Old 08-27-2001, 02:38 AM
CrowHorse's Avatar
Re: engine break-in
Zooky.... Is your mileage figure "corrected" for the tires you are running?
All Good Medicine,
Crow
CrowHorse is offline
post #8 of (permalink) Old 08-27-2001, 04:53 AM
zooky's Avatar
Re: engine break-in
yes, and it still sucks. I am getting 12-13 MPG. I only put on 500-600 miles a year so I can live with it. It runs like a top so I dont want to mess with it. I might be adding EFI this winter, that might help...
zooky is offline
