Pitman Arm Retaining Nut Size? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-23-2001, 05:52 PM Thread Starter
CrowHorse's Avatar
What size is the pitman arm retaining nut? My large sockets only go up to 28mm. Thanks.....
All Good Medicine,
Crow
CrowHorse is offline
post #2 of (permalink) Old 08-23-2001, 10:49 PM
Re: Pitman Arm Retaining Nut Size?
Just took mine off yesterday, it's a 30mm
Rich
'86 Sami
mnraaron is offline
post #3 of (permalink) Old 08-23-2001, 11:12 PM Thread Starter
CrowHorse's Avatar
Thanks Rich! Any problems in removing it?
All Good Medicine,
Crow
post #4 of (permalink) Old 08-24-2001, 05:12 AM
Yeah, it was a major PITA. I did the borrow the puller from Auto Zone and broke the tool, went back and got another and tightened it till it felt like it was going to break too! Left it sit for a couple of hours with some WD40, and then I gave it a wack with my BFH and POP it's off. I hit the pittman arm on the end sideways like, 90 degrees from the retaining nut. Good luck with it!
Rich
'86 Sami
mnraaron is offline
post #5 of (permalink) Old 08-24-2001, 07:30 AM
Yankee Tim's Avatar
Crow,
Save yourself some headache. Soak the pitman real well for 24-hrs in some PB Blaster or WD or similar. Also, get a torch. Butane will do but one of those radio shack micro torches will be more precise.
Clean off the oil (so it won't burn) and heat the pitman on the outside around the steering box shaft. Then use two BHFs. Bob uses a maul and a 4# hammer. Place the maul on one side of the pitman, and smack the other with the BFH. You're trying to use the maul to support the pitman so the force of the blow affects the pitman the most. A few real good whacks should free it (if yer lucky).
If not, doing the same while a puller is attached can help.
This usually works, if not, you'll need to cut it.
Yankee Tim is offline
