Pitman Arm removal ?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-22-2001, 07:36 PM Thread Starter
CrowHorse's Avatar
I know this has been covered before, but could I ask what are the best methods of removing it? I'm awaiting a drop pitman arm and want to be prepared. I know that can be less than cooperative in coming off..... Thanks...
All Good Medicine,
Crow
CrowHorse is offline
post #2 of (permalink) Old 08-22-2001, 07:45 PM
Re: Pitman Arm removal ??
I needed heat on mine and a puller
Dedicated to the restoration and care of the North American Rhino
RHINOGEAR is offline
post #3 of (permalink) Old 08-22-2001, 08:15 PM
Soak it with PB blaster then try a puller. If that doesn't work cut it with a grinder and then give it a smack with a chisel.
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
wildweasel is offline
post #4 of (permalink) Old 08-22-2001, 08:28 PM
Nowhere's Avatar
Go to your favoriate auto parts store and look for the pitman arm puller. It is like a pulley puller but much stronger. They are about 10 or so dollars and are well worth it. They are a pain in the arse to remove.
Got zook?I do,88.5 spoa'd on 29'shttp://www.geocities.com/bik3r
Nowhere is offline
post #5 of (permalink) Old 08-22-2001, 08:32 PM
Be sure and get a good quality puller. I broke a few from Advanced Auto, then bought one from NAPA and it has pulled a couple of arms with no problem. Did you get the arm from Sam??
88.5 Samurai is offline
post #6 of (permalink) Old 08-22-2001, 09:06 PM
Try the above tips to pull it off.
I've had a couple over the years that would not come off no mater what. In those instances, you use a grinder or cutting tool and put a slipce thru it. Then it comes right off. Tends to save hours of frustration.
http://www.rocky-road.com
post #7 of (permalink) Old 08-22-2001, 09:41 PM Thread Starter
CrowHorse's Avatar
Sam dropped it in the mail today. I'm just getting prepared for the removal of the old one. Thanks again for letting me know he had one for sale.
All Good Medicine,
Crow
post #8 of (permalink) Old 08-22-2001, 09:43 PM Thread Starter
CrowHorse's Avatar
Thanks folks for the hints! Can I reuse the nut or does it require replacing?
All Good Medicine,
Crow
post #9 of (permalink) Old 08-22-2001, 10:21 PM
The nut can be removed and reused, don't waste your money or time with a puller. I have destroyed three lifetime warranty Heavy Duty pullers on these things, and hours of frustration. Now I put a new .89 3/32" disc in the 4" Makita and slice the front off the thing and one whack with the hammer and it falls off. 5 minutes vs hours. A clear choice.
TGT - NCO
www.northcoastoffroad.com
NCOffroad is offline
post #10 of (permalink) Old 08-22-2001, 10:52 PM
Cap34
If you're not crazy about cutting right away, put a decent puller on it, tighten it up, and walk away for awhile. I was giving up on ever getting my arm off, and while I was stewing over how to proceed ...POW!! the pitman arm came off. It sounded like somebody drove a Titleist into the car.
