upper coil spring bracket ??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-19-2001, 06:44 PM Thread Starter
I just picked up some coil spring parts (for the rear) and I was wondering what I should use for the upper coil spring mount. I want to attatch it to the frame to get a few more inches of lift. any pics or links would be a great help.
Big Bear,
I'm not crazy,I'm perfectly INSANE![img]/wwwthreads_images/icons/tongue.gif[/img]
Big Bear is offline
post #2 of (permalink) Old 08-20-2001, 09:47 AM
Re: upper coil spring bracket ???
Make your own. Flat plate cut round larger than the OD of the coil. Bolt welded in the middle for a screw down retaining plate.
If you want something pre-fabbed, check with shops in your area that sell to circle track racers. They'll carry lots of pre-fab coil spring mounts and such.
http://www.rocky-road.com
post #3 of (permalink) Old 08-21-2001, 09:34 PM Thread Starter
Thanks Glen for the reply. I thought without the mount being cupped the spring could move under flex? From how you describe it I would have to make a smaller inner circle to keep the spring in place or would a "J" bolt work to keep everything in place? Am I on the right track????
THX
Confused [img]/wwwthreads_images/icons/wink.gif[/img]
Big Bear,
Big Bear is offline
post #4 of (permalink) Old 08-21-2001, 11:13 PM
yes BB you need a cup or a J bolt or something along that line..
Bill Forrest!!............Off-Road Champion.
http://www.geocities.com/zukybill/index.html
Bill4rest is offline
post #5 of (permalink) Old 08-22-2001, 09:03 AM
You can do the inner locator by using a small section of pipe less than the ID of your coil spring.
You might want to take a look at a coil sprung Jeep too. The top of the coil is actyuall not connected. There is a locating tongue about 8-9" long that keeps the spring saddled where its supposed to go.
post #6 of (permalink) Old 08-22-2001, 10:45 PM
I have seen this too, but you still need some sort of a cup to hold the spring. See attached file, It would just be easier to make/use a pipe the size of the OD or ID of the spring with a clamp. I'm doing this in the rear right now and have one on my bench out in the garage. I don't have my scanner so your out of luck! but you could drive down here to Oceanside if ya want.
post #7 of (permalink) Old 08-23-2001, 12:30 AM
Yankee Tim's Avatar
Spidertrax has them pretty cheap, $30 a pair. Sounds like they are just what you need.
http://www.spidertrax.com/hardware_cop.htm
Yankee Tim is offline
post #8 of (permalink) Old 08-23-2001, 08:56 PM Thread Starter
thanks guys. I saw the Spidertrax ones yesterday and I think I may go with them.Thaks again
Big Bear,
Big Bear is offline
post #9 of (permalink) Old 08-23-2001, 09:05 PM
What springs r u using?
ADDICT
post #10 of (permalink) Old 08-23-2001, 09:07 PM Thread Starter
I picked up a set of two door tracker coils. Hopefully with the upper coil mount under the frame will give me a couple of more inches of lift.
Big Bear,
Big Bear is offline
