I need some good advice about faulty driveline - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-07-2001, 06:09 AM
Hey,
I have a 1989 Samurai for 5 years and it has always driven very good, untill now:
*I hear sometimes (mostly when the weather=hot) a whining/screaming noise when a de-accelerate (braking on the engine)
*Also I can feel vibration at low speed, when I'm driving at 20mph or more, the vibration goes away.
I did some test:
* the joints of the 3 axes seems to be OK, there is no great backlash(play,margin,clearance)
* engine and drivetrain-components seems to be solid fixed so the rubbers,... are still good
* There is more play in the front drive shaft, than the one to the back. I checked this when the vehicule was parked and i rotated the drive shafts back and for so this give me an idea about the backlash in the axle reduction by the differential
* When I put the lever of the transfer case in 'N'eutral, and set the lever of the transmission in '4' or '5'(overdrive), then you can here a lot of noise and feel a little vibration, it seems to be coming out of the transfer case or the axle from the transmission to the T-case >> is this indicating there is a ball bearing defect in the T-case, or is there an unbalance in the drive shafts, ..???
So,
Where is my problem (Transmission, T-case or driveshaft or?)
And can I repare the problem (in T-case,transmission or ?)
Can please someone help my, by giving my some advice,
I want to repare my Sam because it has never failed my on the 50.000 miles I have driven in the past 5 years
Thanks for reading,
Danny
post #2 of (permalink) Old 08-07-2001, 07:35 AM
Re: I need some good advice about faulty driveline
have you checked the juice level in the tranny n t/c? i rekon i would start there to diagnose it. could just be low..
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #3 of (permalink) Old 08-07-2001, 07:37 AM
dparker's Avatar
thats where i would start too.
RUN IN TO YOU LATER
dparker is offline
post #4 of (permalink) Old 08-07-2001, 10:36 AM
Use the Force
You need to pinpoint your whining/screaming noise a little better. Try holding tight to the transmission shifter when it is making the noise - feel for the noise. If the tranny is making it, there is a good chance you can detect it through the shifter. Try the same thing with the transfer case shifter.
OILBURNER [email protected]
OILBURNER is offline
