Fuel leaking help? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-05-2001, 06:13 PM
Fuel leaking help?
I have a problem with the canister that sits on the passengers side fire wall and connects to the carb it leaks gas out of the bottom. I dont run a stock carb on my other suzuki and dont use one is the selinoid on the carb bad or is the canister bad? can i remove it and plug off the carb? anthing might help thanks.
post #2 of (permalink) Old 08-05-2001, 10:35 PM
Re: Fuel leaking help?
Replace the cannister.I think thats either for emission junk or an evaporator of some sort.
Hey,I know a shortcut......[img]/wwwthreads_images/icons/smile.gif[/img]
mudslide is offline
post #3 of (permalink) Old 08-06-2001, 02:26 AM
Vapor storage device, can stuffed with charcoal.
Collects off vapor from fuel tank and carb. when engine
is not running. Then when engine does run sends to manifold
via mix with air burns vapor under combustion.
You should not gas leaking out of it... unless sam is
turned upside down fuel flows thru vent system.
Check your liquid vapor seperator,location rear pass side
remove panel, see small plastic container if it's full of
fuel some how your fuel being push up thur vent system how
that would happen escapes me completely.
More logical explanation is carb solenoid open and float
stuck open or ajd. incorrectly allowing fuel backflow into
vent canister.
Vent canister is at atmosphere and manifold neg pulls
air thru it when engine is running.
Later
post #4 of (permalink) Old 08-06-2001, 02:27 AM
vent canister.
Later
post #5 of (permalink) Old 08-06-2001, 02:27 AM
