Toy axles - tech. details needed - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-04-2001, 09:51 PM Thread Starter
I'm sure this topic has a long and boring history, but here it comes again:
- the year of a donor Toy pickup would be '85 or older.
AFAIK, the '85 has biggest gussets, the '84 a bit less, the '83 and older even
less and are narrover by about 1" p/side, right???
- the driveshafts - do you guys use two front ones (with the CV-joints) and
shorten/lenghten them as needed???
- having above figured out, is the spline lenght sufficient for a serious
amount of flex, or I better go for a custom-made shaft???
Anything else I should consider before I go out and spend my aftertax $$...BTW, just got a nice letter from Revenue Canada "....you have been selected for an audit"....they make it sounds, like I should consider myself lucky...bloody bastards.
-marker
mark_er is offline
post #2 of (permalink) Old 08-04-2001, 11:49 PM
Zuk Jr.'s Avatar
Re: Toy axles - tech. details needed
I'm going to do the swap very soon! Talk to Tim (Oilburner) he has toy axles under his rig and has e-mailed me some very good ideas! I have the front drive shaft that I'm going to use for the rear. It bolts right up to it. I think you have to have the bigger flangs (14m bolts) for it to fit right to the t-case? The CV joint helps out well for the rear axle since it is centerd. I think the toyota shaft is long, I'd have to look at mine, I'm sure it is longer then the stock Zuk's! I'm just waiting on some $$ so I can install a locker in the front! Looks like an easy swap. Like I said before...ask Tim for some help, he knows what you need! LAter
-Brian
<font color=blue>THE ULTIMATE ZUK</font color=blue>
Zuk Jr. is offline
post #3 of (permalink) Old 08-05-2001, 07:21 AM
The front shafts come in two lengths prior to '86(?). One for the 4 speed and the other for the 5 speed. The drive shaft to suit the five speed is about 8-12" longer than the four speed shaft. It makes up for the extra length of the 5 speed box.
Zooky Matt
'88 Sierra,16v efi 1.6L, 4.16 transfercase, Hilux diffs, 4.88 ratios, Locked rear, SPOA, 33" Swampers
post #4 of (permalink) Old 08-05-2001, 09:53 AM
Let me know how this one pans out, I have an extra '85 front axle housing with dropout (left from disk brake conversion on my L.C. conversion) which will interchange with all '79 up solid axle housing.
ZOOK94 is offline
post #5 of (permalink) Old 08-05-2001, 12:56 PM Thread Starter
Zuk Jr. wrote:
....>> I have the front drive shaft that I'm going to use for the rear.
So....I understand, that for the swap two front Toy d/shafts are needed???? I guess so.
However, by doing this swap, we induce an extra driveshaft angle here caused by the Toy rear pumpkin being "off_center" relative to the T/case. Hence one more question here:
since the Toy rear pumpkin is centerd, we are dealing with the following scenario: Sammy_T/case_output-->Toy_CV_joint-->d/shaft_tube-->Toy_single_u-joint-->Toy_centered_pumpkin.
The first CV joint in this picture sends vibration_free power down the tube. Then we have an angle mentioned above that is dealt with by the second (single) u-joint. Theoretically it will cause off-synch effect and vibration on the wheels, right?? I suppose two CV joints would fix that, but is it really needed???
Would someone with this swap done please share his/her experience on that.
Tq
-marker
mark_er is offline
post #6 of (permalink) Old 08-05-2001, 01:43 PM
Zuk Jr.'s Avatar
Okay, to help clear what I said I found the e-mail that Tim sent me a while ago! Tim, I hope that you din't mind if I use this!
Here ya go...
Brian,
>First let's talk about physically getting the Toyota axles undre a
Samurai.
>The odds are that you have 4.10 gears in the axles, if they are stock,
>although some came with 4.56's or even 4.88's (rare, tho) For the
front,
>you can use the factory spring perches where they are, but make sure
you
>get the u-bolts & plates if the u-blts pointed "upward". If they
pointed
>downward, you will have to do some modifications get them to point up
like
>you want. You willneed to modify your steering, also. I picked up an
>extra driver's side steering arm, cut off the curved part, and turned
it
>upside down & used it on the passenger side to make a half-assed
crossover
>steering. Then I made a custom drag link - I had to notch my froam to
>clear the bar, but if you have arched springs or enough body lift, you
>might not have to do that. Besides, with Boggers I'm afraid that arm
>wouldn't be strong enough - they will bend. I will run mine like it is
>until it bends, then I will buy the All-Pro steering kit (big money)
Or
>you could just make a z-link w/ Samurai stuff on one end & Toy on the
>other. For those Boggers, I'd Seriously consider going ahead &
changing to
>power steering. Go ahead & get you some longer brake hoses - the
Toyota
>ones will fit hte samurai hard lines. If you have the bigger Samurai
bolt
>pattern on your driveshaft flanges (the one that uses 14MM wrench)
then
>your stock front driveshaft will bolt in.
>On the rear, you'll need to by a pair of spring perches, and you will
have
>to run you some new hard lines to match the Samurai lines. Can't
remember
>if I was able to use stock ubolts or not -seems like they were too
short?
>Now this next part is IMPORTANT: you said you have a Toy driveshaft
-- you
>mean the Front one with the double-ujoint, right? It is Excellent to
use
>that in the rear, since the chunk is centered. When you weld your
perches
>on, you want the pinion to be pointing RIGHT AT THE T-CASE FLANGE to
use
>that driveshaft. NOT just up from level a tad like w/ regular shafts.
You
>will need to do a little fab work to get the driveshaft to fit on the
Zuk
>flange. I reccommend taking the double-ujoint apart and having the
little
>lip on it machined down so it will fit inside the zuk flange- then,
turn
>the bolt patterns pattern 90 degrees & drill the Toy patten on the zuk
>flange. It sounds complicated, but it's not bad - I had access to a
small
>bench lathe & did mine myself. Of course you will have to shorten the
>driveshaft - A LOT!!! It is painful to look at, but mine has held
>together so far. Have it balanced, too. You will have to rig up your
>e-brake. I will tell you one more thing, and you must be honest with
>yourself -- if you tend to put your foot in it , you are going to have
>awesome axle-wrap, especially in the rear. Not only is this
dangerous, you
>will Ruin rear springs constantly. I built a ladder bar which does
not
>limit my articulation, and it fixed this. You will need one, too.
>That should be enough to either scare you out of swapping the axles,
or
>convince you that you'r on the right path I currently run
BFG M/T
>35's and have had no problems w/the Birfields or anything. I run
>LockRights front & rear, and have the high-pinion FJ-80 diff's Front
And
>Rear - it helps a lot w/ the chunk offset. I know what you mean about
the
>rear locker, but with the heavier Toy axles it's not nearly as bad as
with
>the lighter zook stuff. Still, you need Something in the rear - you
might
>want to check into the Gearless Locker, also they are starting to make
an
>electronic locker for the Dana's - Toyota shouldn't be too far away.
You
>are saying you are gonna put a big V-6 in your rig - I do not have Any
>experience with that kinda power! I do have the VW diesel which is
>considerably stronger than the Suzuki engines, but not like what
you'll
>have. I guess I would talk to Toyota guys w/ in their trucks & big
Boggers
>& see what they run. Your Samurai will be a Lot lighter, so you
should be
>able to get away with a little less gear than they do.
>If it were me, I'd be tempted to go completely with the Chevy
drivetrain,
>t-case & all. This would mean custom driveshafts, but your gearing
would
>be much better because the Samurai t-case is reduced lower than 1:1
even in
>2WD - this is Not good for that V-6 which will want lower rpm's. Once
you
>get the bugs worked out of the engine/tranny/tcase swap, I'd probably
try
>the 4.10's just because you got 'em & see how it works. You will have
to
>be careful when talking to guys to get their opinions- many times,
what
>they think is acceptable will not be driveable on the street.
>Good Luck,
>Tim J
This is a pic of what Tim was talking about with the steering system (no, this isn't Tim's rig)
-Brian
Zuk Jr. is offline
post #7 of (permalink) Old 08-06-2001, 12:04 AM Thread Starter
Ooooo, this is a good portion of info there. Definitely two front Toy d/shafts are needed - I was guessing correctly.
Thx man!!!
-marker
mark_er is offline
post #8 of (permalink) Old 08-06-2001, 06:06 AM
Zuk Jr.'s Avatar
Yeah or just the CV style joint on both ends! Shouldn't be that hard to cut one off another D/S and weld it on, take it down to the D/S shop and have them balance it out for ya! Glad that the info helped ya out.
-Brian
Zuk Jr. is offline
