valve cover gasket!!!!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-31-2001, 09:32 PM
How the heck do I get this thing not to leak? I couldn't find anywhere in my worthless hanes manual how hard to tighten the bolts. I've already ruined the gasketI bought earlier today, How to I make the next one work?
Jeff Thompson
87 "Stanley" The Samurai, in his stock form
post #2 of (permalink) Old 07-31-2001, 09:42 PM
CrowHorse's Avatar
Re: valve cover gasket!!!!!
It could be your valve cover is bent up where it meets the head. Verify that this is straight and true. The 4 mounting bolts shouldn't need to be very tight. They are only 6mm bolts that thread into aluminum. Too much torque and you'll strip the threads.....
All Good Medicine,
Crow
CrowHorse is offline
post #3 of (permalink) Old 07-31-2001, 10:32 PM
Cam shaft cover torque spec is 3.0 to 3.5 ft lbs.
Neal the Zukiguy
"If it is '...a Jeep thing...' I hope it isn't contagious"
post #4 of (permalink) Old 08-01-2001, 06:59 AM
Scott_CJ8's Avatar
Don't over-torque the four bolts holding it on. I used a cork gasket with that "form-a-gasket" compound on both sides, no leaks. Be sure your valve cover isn't warped.
Scott Trester - '88.5 Suzuki Samurai
http://RockPile4x4.tripod.com/Scott.html
Scott_CJ8 is offline
post #5 of (permalink) Old 08-01-2001, 07:25 AM
I just did an engine rebuild and the cork gaskit that came with the kit didnt fit worth a crap on any of the 3 valve covers that I have laying around. I ended up trimming the gasket and using gaskit maker to get it to fit correctly. I am going to try and get another gaskit hoping that the one I got was junk.
"Happiness is a Belt Fed Weapon!"
lav25 is offline
post #6 of (permalink) Old 08-01-2001, 07:33 AM
I had troubles getting my valve cover to not leak also. It keps popping in along the sides in the curves. I finally got a Suzuki gasket, it was much stiffer than the other 3, it is almost a cardboard type material or very dense cork. I used Permatex spray tack and glued the gasket to the valve cover, 2 coats a few minutes apart then let it tack up good and stick the gasket to the cover. Then I installed it to the head dry. No more leaks!! Fianlly.. 4 gaskets later...
93 Tracker, ProComp, Calmini, 31's, Thorley, K&N, etc..., aka the donor. Looking for a donee..
Mini4x is offline
post #7 of (permalink) Old 08-01-2001, 07:44 AM
Two words about the valve cover gasket which will make your life MUCH easier....DEALER PART! They're only a couple bucks more but they are 500% better! Trust me. I went through 2 cheapies before I gave up and bought one from the dealer.
AARRRRRRRG! 1987 Red JX 'vert, 4.5 BREEZE SPOA, SJ410 T-case (not sure how I like it), 29 Super Swampers (31 BFG M/T knock offs - eventually) AARRRRRRRG!
Capn_Crunch is offline
post #8 of (permalink) Old 08-01-2001, 08:05 AM
I blew the side out of my gasket at the melt. It was one out of a rebuild kit. I replaced it with one from Napa and to the correct torque and its not leaking. Even with no sealer.
Tim Evans
88 Coiled Samurai
"Zukor"
post #9 of (permalink) Old 08-01-2001, 10:53 AM
I don't use a gasket. I used a RTV silicon sealant. No leaks in six years.
Marc Haught
[email protected]
www.serioussami.rockcrawler.com
Sami is offline
