cheapest way to get on top of 33's - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-30-2001, 03:34 PM
zukikid
cheapest way to get on top of 33\'s
ok ...got some 33/12.5/16.5 grabber ats i want to get on top of #1 i know i am going to have to get custom rims to run these tires .# 2 i would like to stay away from a body lift or a large shakle lift if at all posible.#3 already have spring pads extended brake lines. #4 did i mntion i would like to do this as cheap as possible :-)
any help would be greatly apreciated
zukikid
proud owner of the SUPER stock zuk. :-)
post #2 of (permalink) Old 07-30-2001, 03:42 PM
Re: cheapest way to get on top of 33\'s
You already have it.
1.You can uses stardard black "rock crawler" wheels they will rub a bit when all the way over.
2. I ran my 33 with a modified SpOA. (made 1/2" taller spring perch)
I did not need body lift or longer shackels
3. I did all of it for less than 50 buck and you already have half of what you need.
4. I added a leaf from a cj-5 and got an extra inch of lift 3/4 now after sag.
5. Don't forget about doing the shocks
Where did you get those tires 16.5 inch rims???? That might be a problem.
I Work to Wheel, because I wheel, I work.
http://www.geocities.com/zuk_tonka/zuk.html
post #3 of (permalink) Old 07-30-2001, 03:59 PM
zukikid
16.5 inch rims are a full size ford/ chevy thing .most of those rims came with 6 or 8 lugs.i got to use them though ,i just got them so damn cheap.i plan on having rims made for the 5 on 5.5 lug pattern ,i have to any way to get the back spaceing i need
post #4 of (permalink) Old 07-30-2001, 04:24 PM
Brown29's Avatar
Cheapest? Try a cutting torch... it'll get that excess metal around your wheels out of the way to make room for them big tires. No lift needed.
Email: [email protected]
Brown29 is offline
post #5 of (permalink) Old 07-30-2001, 04:47 PM
they had an article on that in one of the off-road magazines! It looked sporty but I would cut it straight off to the front! yep just go at a angle on the body side to a certain height then just cut it clean off! It seems like it would be dificult to perfectly cut both perfect though??!!
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
72 fj40/crate 350/33's/discs
