Rear Toyota Axle Perch - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-30-2001, 01:53 PM Thread Starter
In converting to a rear toyota axle, has anyone left the toyota perches
and welded a set sold for a samurai axle on also. Doing this and leaving
a gap of about 1/2 inch and a drilled plate over the perches with the
hole over the gap one sould be able to use mount things up. Additional
holes are required in the existing perches so that the U-bolts can pass
through them ( instead of around them ).
LoneZuk
lonezuk is offline
post #2 of (permalink) Old 07-30-2001, 04:17 PM
Re: Rear Toyota Axle Perch
If I think I get you right, your using bolts instead of U bolts right? Like the toyota guys are doing?
If you do this remember that ALL the forces in axle wrap that occur will be PULLING and PUSHING against the spring perch. Instead of just pushing with a normal U bolt type ste up.
Bill Forrest!!............Off-Road Champion.
http://www.geocities.com/zukybill/index.html
Bill4rest is offline
post #3 of (permalink) Old 07-30-2001, 04:32 PM Thread Starter
Since its in the rear, I plan on using toyota U-bolts in combination with the
curved plate(s) that are used under the toyota axle. I have to drill the perches
so that the u-bolts can fit through.
Using bolts, instead of the ubolts will give some extra axle clearance for sure,
but can be weaker and the axle is not in the sandwich in case of failure.
LoneZuk.
lonezuk is offline
