Rebuilt engine break in oil viscosity suggestions? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-27-2001, 12:12 PM Thread Starter
I am about to drop in a newly rebuilt engine that I have been working on and was wondering what type or weight of oil I should use in it. It is .020 over, with flat top pistons, and reground cam. Any suggestions??
"Happiness is a Belt Fed Weapon!"
lav25 is offline
post #2 of (permalink) Old 07-27-2001, 12:20 PM
longzuk's Avatar
Re: Rebuilt engine break in oil viscosity suggesti
you can use just about any oil to break it in, I use 15/30 in my bike engine the last time i rebuilt it.
WHATEVER YOU DO, DON'T USE SYNTHETIC UNTILL IT IS BROKEN IN..
Sean
SIZE DOES MATTER 85 LWB 31'S LINCOLN LOCKER RR,CTR FORCE DUAL FRICTION, CUSTOM BUMBERS & GAS TANK PLATE, SPOA BOBBED 6 INCHES CUSTOM SPORT CAP
longzuk is offline
post #3 of (permalink) Old 07-27-2001, 01:04 PM
why shouldnt you use synthetic?
Steve [img]/wwwthreads_images/icons/cool.gif[/img]
'88 Suzuki Samurai
'99 Toyota Tacoma (Tow Vehicle)
[email protected]
Texas A&M Off-Road
FTAC of 2003
TexasA&MOffRoad is offline
post #4 of (permalink) Old 07-27-2001, 01:20 PM
Nowhere's Avatar
Synthetic oil does not allow the metal to contact and create wear patterns (breaking in).
got zook?
http://www.geocities.com/bik3r
29x10.5x15 SS TSL *SX*, Calmini Header, SPOA, Lights, Dupicolor, Z-bar, Xenon lights, diamond plate rockers, tubes front, rear, & sides!
Nowhere is offline
post #5 of (permalink) Old 07-27-2001, 01:38 PM
Re: Rebuilt engine break in oil viscosity suggestions?
From what I know, your engine builder should be the one answering that question. It depends on the bearing tolerances and such. I would most likely use a thinner oil flows to dry parts faster.
93 Tracker, ProComp, Calmini, 31's, Thorley, K&N, etc...
Mini4x is offline
post #6 of (permalink) Old 07-27-2001, 01:55 PM
Well run the oil viscosity that is right for the temp range of the season. Prelube the engine,(crank it for awile with no power to the coil No gas in carb till the oil pressure is built up some then start it. You did get the head gasket on the right way? If you don't you will wipe out the head.
When I did mine I think it was written on the gasket"This side up" or some such. And I checked all the holes to make sure they lined up.
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
wildweasel is offline
post #7 of (permalink) Old 07-27-2001, 02:08 PM
lav25 in the engine builder. I advised him to use the same weight oil that the factory manual recommends.
zoomy4 is offline
post #8 of (permalink) Old 07-27-2001, 02:14 PM
"Synthetic oil does not allow the metal to contact and create wear patterns (breaking in)."
if there is metal to metal contact your motor isn't gonna
run long,the oil is supposed to keep the metal FROM touching
each other.otherwise you are wearing the motor heavily.
synthetics are ok to use in a new or rebuilt motor,the come
in some cars from the factory for years.it's just a old wife's tale about it not being used in new or rebuilt engines.
post #9 of (permalink) Old 07-27-2001, 02:27 PM
To state across the board that you can use syntetic oil is
a disservice to say the least. read the instrutions on the back of the oil bottle sometime. Most state not to run in a new or re-built engine. The rings will not seat in properly
depending on the ring material. It took my rebuilt engine
allmost 2K miles to seat in fully, and this was with regular
multigrade oil.
Glenn
post #10 of (permalink) Old 07-27-2001, 02:33 PM
how do you know when the rings have seated?
'88 Suzuki Samurai
[email protected]
Texas A&M Off-Road
FTAC of 2003
