1.6 conversion - how much lift? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-27-2001, 10:26 AM Thread Starter
how much lift is required to install a 1.6 liter?
Steve [img]/wwwthreads_images/icons/cool.gif[/img]
'88 Suzuki Samurai
'99 Toyota Tacoma (Tow Vehicle)
[email protected]
Texas A&M Off-Road
FTAC of 2003
TexasA&MOffRoad is offline
post #2 of (permalink) Old 07-27-2001, 10:32 AM
Re: 1.6 conversion - how much lift?
The 1.6 has a longer (taller) cylinder rather than a larger diameter. The decl on the 1.6 is 2" taller than the 1.3. So you will need a 2" bod lift at least, as well as a longer exhaust to reach the manifold.
Neal the Zukiguy
"If it is '...a Jeep thing...' I hope it isn't contagious"
post #3 of (permalink) Old 07-27-2001, 10:38 AM
I was just told that if I had a SPOA I won't need the body lift to clear the 1600 cc motor.
Jason
Refer to engine options post
I Work to Wheel, because I wheel, I work.
http://www.geocities.com/zuk_tonka/zuk.html
post #4 of (permalink) Old 07-27-2001, 10:45 AM
How does a SPOA move the body up without the engine? I'm confused? It's not the oil pan that is the problem, its the hood.
Neal the Zukiguy
post #5 of (permalink) Old 07-27-2001, 10:46 AM
Jbird's Avatar
I heard it was an oil pan issue. If you use the 1.6 oil pan you need about 3" lift.
There is a way to use the 1.3 pan by welding in the 1.6 pick up tube. Then you wouldn't need any lift.
This is just what I've heard and not my experience.
[img]/wwwthreads_images/icons/cool.gif[/img][email protected]
http://www.geocities.com/jbird88_5/index.html
Jbird is offline
post #6 of (permalink) Old 07-27-2001, 10:48 AM
The oil pan is what presents a problem with the 1.6 conversion. There is questionable clearance between the oil pan and the top of the front axle. As a minimum, I would recomend a basic SPOA lift, though there is a way to modify the 1.3 pan to be used. A body lift would not work because it does not increase the distance between the oil pan and axle, only between the body and frame (the engine and suspension are both attached to the frame)). A body lift would be helpfull if you wanted to retain the "over the engine" intake tube. The stock Samurai intake will fit over the 8v TBI, provided you drill two holes through the intake that line up with the two threaded posts on the TBI.(remember to plug the center hole).
"Reality goes on without me!"
whazoo is offline
post #7 of (permalink) Old 07-27-2001, 10:54 AM
Whoa, Calmini told me there was no hood clearance because of the higher deck on the block... DA DUM! Scary. That's why I love this page, you can get second opinions on everything so you don't have to take one mans word for something.
Neal the Zukiguy
post #8 of (permalink) Old 07-27-2001, 11:08 AM
I don't have a body lift on mine - works fine and I have the Calmini kit.
zoomy4 is offline
post #9 of (permalink) Old 07-27-2001, 12:14 PM
for a 1.6 conversion, the oil plan is the clearence issue. you will need suspension lift for that, the simplest anyways. IIIIFFFFFFFF you are going to use the 1.6 tracker/kick efi, thats when the body lift is needed for clearence reasons of the efi unit. i have HEARD that you can *massage* the underside of the hood n make it work fine, but, I DONT KNOW FOR A FACT. i have a 2 inch body lift.
BiLLy bOb
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #10 of (permalink) Old 07-27-2001, 01:00 PM
If you allready had a SPOA lift and were afraid of the hood clearnace. The easiest way to get the clearance would be to make your own engine mounts that lowered the engine an inch or so. I'm talking about the metal mount between the engine and the rubber block. They are easy to make...just get good measurements and the angle right, and you can incorporate the 1.6 rubber mounts also. Way easier than installing a body lift!
whazoo is offline
