new zook but ,no r.p.m.'s - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-12-2001, 08:12 AM
pook
new zook but ,no r.p.m.\'s
just bought a new zook 88.5 NO RUST,low miles and no power?
the little guy does great in first through third hitting around four to five grand then into fourth it's having a hard time holding three thousand r.p.m's and in fifth it just falls flat,nothing starts loosing speed and you have to down-shift to third to get back to fourty m.p.h.
and thats about the top speed,checked engine compression and it's ok. timings set at 10 before top dead center,
so anybody know what i'm missing here??? or any suggestions?
thanks
jeff
post #2 of (permalink) Old 07-12-2001, 08:19 AM
dparker's Avatar
Re: new zook but ,no r.p.m.\'s
need more info what size tire you got ? still have factory exuast and cat? what kind carb factory? is it missing or does it grandley drop rpm ? new fuel filter? what your plugs gapped at?
RUN IN TO YOU LATER
dparker is offline
post #3 of (permalink) Old 07-12-2001, 08:49 AM
pook
that was quick, ok,
tire size is 205-70-15
factory exhaust and cat.
asian carb (factory i think)
on r.p.m.they just drop off,no missing
fuel filter was replaced when i got it,thought that might be the problem.
and the plugs are at .030
head--keeps banging on side of zook due to fustration!!!
thanks
post #4 of (permalink) Old 07-12-2001, 09:53 AM
Pook, look to your fuel pump..mine did that when the pump was going....also, look at your distributor cap, check for any cracks.
HTH,
R/T
88 Samurai, 1300 bored .020,Power Punch II head w/1600 exhaust valves,Low End AAPA cam,Weber,Calmini Header,2" Exhaust System,31/13.50/15 Baja Belted Radials
post #5 of (permalink) Old 07-12-2001, 11:43 AM
mike shannon
go underneath it and hit the converter with a fist and see if you can here it rattle. i have had this happen too three different zuks. the monolith breaks free and works like a check valve. i would also put in a fuel presure gage and run it down the road and see if it is dropping. my 2 cents mike
zuks and toys
post #6 of (permalink) Old 07-12-2001, 12:18 PM
longzuk's Avatar
I agree with mike on this one, my wife's rx7 did the same sorta thing, changed cat ran after that.
Later Sean
SIZE DOES MATTER 85 LWB 31'S LINCOLN LOCKER RR,CTR FORCE DUAL FRICTION, CUSTOM BUMBERS & GAS TANK PLATE, SPOA BOBBED 6 INCHES CUSTOM SPORT CAP
longzuk is offline
post #7 of (permalink) Old 07-12-2001, 01:11 PM
Nowhere's Avatar
See if you can bog the engine down in 1st or second gear at higher rpm (emulate the 4 and 5 gears but real slow). Eliminate the tranny. No power at the upper end in all gears? Change the air cleaner and maybe unbolt the exhaust and then run it again. hheheh, would be kinna loud, but oh well <G>. Your bearings could be going also, lots of drag @ high speed... Make sure everything is good and lubed..
got zook?
http://www.geocities.com/bik3r
29x10.5x15 SS TSL *SX*, Calmini Header, SPOA, Lights, Dupicolor, Z-bar, Xenon lights, diamond plate rockers, tubes front, rear, & sides!
Nowhere is offline
post #8 of (permalink) Old 07-12-2001, 02:02 PM
HAVE SOMEBODY REV THE ENGINE WHILE YOU PUT YOUR HAND OVER THE TAIL PIPE IF NO OR LITTLE EXHAST COMES OUT ITS THE CAT IF ALOT COMES OUT THE CAT SHOULD BE FINE
SEE YA QUENT
PS sorry i was yelling
88 zuki,s/r,header,1600,locked in the rear and weber carb. with mitsu seats and 2"inch pipe
87 zuk spoa (new project)
IF GOD IS YOUR CO-PILOT SWAP SEATS
GODSZUK is offline
post #9 of (permalink) Old 07-12-2001, 03:11 PM
Uhummm...you have check your brakes, right??? It sounds like a drag to me; if your problem is speed_dependend, that usually comes down to brakes (stuck, seized, e-brake full_time engaged, etc. - comes with the funny smell :-) or bearings (wheel, diff - comes with the funny noises :-).
Why don't you try this: go down the hill in NEUTRAL, and see if the truck accelerates freely all by itself. You should be able to feel the resistance if any. Alternatively you could just push it on the flat pavement as well, but you should try to simulate the problem circumstances as close as possible....just my .02
-marker
mark_er is offline
post #10 of (permalink) Old 07-12-2001, 04:10 PM
dparker's Avatar
just a quick question what was you cylinder presure at?
RUN IN TO YOU LATER
dparker is offline
