What do I disconnect to tow? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-09-2001, 07:15 AM Thread Starter
OK, I'm over the fear of towing the Sami to Attica. Now, what do I need to do to the Sami to prep it? Remove the driveshafts, remove 1 driveshaft?put it in neutral...what?
I've never towed anyhting this big this far.
Thanks,
Pauly
AARRRRRRRG! 1987 Red JX 'vert, 4.5 BREEZE SPOA, SJ410 T-case (next week), 29 Super Swampers... more to come.... AARRRRRRRG!
Capn_Crunch is offline
post #2 of (permalink) Old 07-09-2001, 07:24 AM
DannyL's Avatar
Re: What do I disconnect to tow?
If you have locking hubs up front, unlock them. In the rear I just unbolt the diff end and tie the shaft up on to the body. Or you can just remove it all toghether.....
DannyL
Pony Express
http://www.partszuki.homestead.com
DannyL is offline
post #3 of (permalink) Old 07-09-2001, 07:26 AM
i ussually just put the tcase in neutral and the tranny in second... but i only tow 100 miles one way ussually... since you'll be going a long way, i would just remove the rear shaft, especially since you'll have more than enough help to put it back on once you get to attica... you should be able to just remove it from the axle and then wire it up somewhere under the body to keep it out of harms way... make sure you unlock the hubs so the front tires can spin independant... also make sure you have the key in the ignition... doesnt have to be in the ACC position, just turn the key on, and then off again without removing it and the wheel will stay unlocked
let me know if you have anymore questions
Steve [img]/wwwthreads_images/icons/cool.gif[/img]
'88 Suzuki Samurai
'99 Toyota Tacoma (Tow Vehicle)
[email protected]
Texas A&M Off-Road
FTAC of 2003
TexasA&MOffRoad is offline
post #4 of (permalink) Old 07-09-2001, 12:49 PM
AAARRRGGG!!!! RAISE THE MAINSAIL!!! HOIST THE ANCHOR AND SHOVE OFF!!!! This time DO NOT USE VICE GRIPS ON THE BOLTS WHEN YOU TAKE OFF THR DRIVESHAFT!!!!!!!
ROB
post #5 of (permalink) Old 07-10-2001, 12:31 PM
Cap34
Talk to Petroworks about converting your transfer case to 2wd low. According to Gary, the conversion allows you to get into "true neutral", Just tow away!
post #6 of (permalink) Old 07-10-2001, 12:45 PM
thats the route im going man. $45 for a machined shifter rail to drop in my t/c. think there is a 20 or so core charge on the rail, but thats no prob. in the end, $45 + shipping.
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #7 of (permalink) Old 07-10-2001, 12:46 PM
Hey Pauly
You can disconnect the rear driveshaft, stick the tcase in neutral, unlock your front hubs, put the tranny in 2nd gear, and leave the key in the ignition to keep the steering wheel unlocked.
Do some practice towing around your neighborhood before you get out on the real road. Also remember you cannot back a flat towed vehicle, and be careful on sharp turns since the ZUK has to track the tow vehicle and the ZUK wheels can jackknife the setup.
Give me a hollar if you need any other tips.
"Happiness is a Belt Fed Weapon!"
lav25 is offline
post #8 of (permalink) Old 07-10-2001, 01:32 PM
As per SUZUKI you can flat tow up to 200 miles with the drive shaft in. But I have a GRSII with the two low kit and it's only 4 bolts and 5 min to disconnect the drive shaft, I'd rather do that then possibly crap out my $1200 T-case.
Bill Forrest!!............Off-Road Champion.
http://www.geocities.com/zukybill/index.html
Bill4rest is offline
post #9 of (permalink) Old 07-10-2001, 03:03 PM
There's also the added benefit that you won't rack any more miles while it's in tow. I've recently picked up a tow dolly and noticed that with the tcase in neutral and the tranny in 2nd, it still put miles on the ODO. I plan on disconnecting the rear shaft for anything more than 100 miles one way.
Mark
1986 Suzuki Samurai soft-top
1999 Toyota Tacoma
http://members.home.net/marvinmartian
mmartian1969 is offline
