nissan motor swap photos - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-07-2001, 06:55 AM Thread Starter
dparker's Avatar
this nissan 1.8 fit in there like a glove had to put a clutch master cylinder in and shortin tranny / tcase drive shaft and use the nissan input shaft end and modify they mount just a hair other than that no problem easy wiring .
RUN IN TO YOU LATER
dparker is offline
post #2 of (permalink) Old 07-07-2001, 06:57 AM Thread Starter
dparker's Avatar
Re: nissan motor swap photos
underneth shoot of tranny
RUN IN TO YOU LATER
dparker is offline
post #3 of (permalink) Old 07-07-2001, 08:15 AM
how is the powerband of the 1.8?? what nissan did they come in?? yours is carbureted i assume? thanks for info!
cueball
88 hd-top,1.3with weber, calmini cam,headers & 2" exhaust, jacobs ignition, 3" national spua , 4.16 tc gears, 88.5 5th gear,29x10.50 swamper tsl sx's
cueball is offline
post #4 of (permalink) Old 07-07-2001, 08:24 AM Thread Starter
dparker's Avatar
came out of a middle 70,s 280z carburated runs like a stripped a$$ ape.
RUN IN TO YOU LATER
dparker is offline
post #5 of (permalink) Old 07-07-2001, 08:33 AM
has it got plenty of low end torque? how about 5th gear --does the ratio work out similar to sami trans? it sounds like you were able to use stock mtr mounts modified ? is cooling a problem? is the setup much heavier than stock? how much exhaust modification did you have to do? sorry if i sound like a 1st grader asking questions but i,m ready do do some sort of swap & am not completely sold on the 1.6 8 valve & don't want to go to fuel injection. thanks for info!
cueball
cueball is offline
post #6 of (permalink) Old 07-07-2001, 08:48 AM
mike shannon
if it came out of a 280z it would be a six cylinder,it more than likely came out of a old 200sx. just a guess, but sure on the 280z part. later mike
zuks and toys
post #7 of (permalink) Old 07-07-2001, 09:46 AM
good lookin swap man. can you give us more info n pics on it???
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #8 of (permalink) Old 07-07-2001, 10:18 AM Thread Starter
dparker's Avatar
not sure if it was a 280z all i came remember is that it was a 200 something z we didnt take time to look at it that much we just blue wrenched it out and left .LOL yeah i will get some more pictures on here tommorow to busy today got a demo derby to run in tonght
RUN IN TO YOU LATER
dparker is offline
post #9 of (permalink) Old 07-07-2001, 10:55 AM
I'm doing a nissan in my zuk also as soon as we get around to it,But i'm doing the Z24 from a 85 nissan 720 pick-up.My brother has done one in a zuk he had and it fit great sounds like you had to make the same mods. for yours as he did,he ran a 5 speed but the one i'm using is a automatic and it's a 2.4L i'm not sure if we will have to move my t-case back any but with the 5 speed he didn't have to and no body lift was needed to run the 5 speed i hope i'm not going to need one to clear the tranny in mine.And should have all the power that i'll need with the carb. motor.
QuadZuki,87 spoa,33"wild countrys
post #10 of (permalink) Old 07-07-2001, 11:01 AM
240, 260, and 280 z cars all had 6 cylinder engines. They were not ever offered with a 4 cylinder. The car you are talking about is 200 SX witch came with the 4 cylinder. Depending on what series you have a L20B (this number will be cast into the pass. side of the block) with a 21-psi of boost makes 275 HP.
N/A
