Home made YJ kit?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-03-2001, 11:30 PM
Home made YJ kit??
check this out fellars and tell me if you think it would work or not cause I got a guy willin to sell for 50 bucks!!
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
72 fj40/crate 350/33's/discs
post #2 of (permalink) Old 07-03-2001, 11:49 PM
Pooh-Bah
DougO's Avatar
Re: Home made YJ kit??
Are you having a shackle at both ends? If so that wont work. I though have a rear kit I have had made which will have drop link style shackels which fit the samurai end and wrangler end without welding that little tube on the samurai rear. Almost done, just have to finish welding the shackle up. Total cost was $70 since it was all a few pieces of each design not a big order.
DougO is offline
post #3 of (permalink) Old 07-04-2001, 07:34 AM
depends on how your going to mount the front eye of the spring. if its going in the factory spring eye mount, your going to considerably stretch the wb on it. they rear shackle would lay flat or close to it unless you make xpander/missin links like doug is doing.
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #4 of (permalink) Old 07-04-2001, 07:41 AM
Doug i would like to see pictures of what you have done when you are finished. Sounds interesting.
mxnhid is offline
post #5 of (permalink) Old 07-04-2001, 08:32 AM
Pooh-Bah
DougO's Avatar
Sure thing, gonna have the welding done thursday at work, but they actually work now, but can be over extended as the stop has to be welded in.
DougO is offline
post #6 of (permalink) Old 07-04-2001, 08:50 AM
So even if I welded the front hanger of the rear spring to the frame it still would not work??... then what if I just ran out the shackle out the back??
Thanx
Studly
post #7 of (permalink) Old 07-04-2001, 09:38 PM
Just a reminder, please send me some pics. I would be interested in seeing them and how it functions. I think i want to put this set up on my wifes rig but possibly no expanding shackle. Max
mxnhid is offline
post #8 of (permalink) Old 07-04-2001, 10:37 PM
Pooh-Bah
DougO's Avatar
If thats the case, then all you need to do is make up 4 metal plates to bolt into the sides of the current hanger but extend it out like 3" so you can put the wrangler spring more foward, I used the original factory holes and drilled 2 more 1/2 holes per plate with grade 8 bolts. I also wanted it to fit in with my nerf bars and the CSC thing wouldnt have .. If I wanted, to I could make everything work with just nuts and bolts, plates and shackles, but I want to weld the shackles up, so the stop for the expanding is welded in ..
DougO is offline
post #9 of (permalink) Old 07-04-2001, 11:06 PM
same here! I just did not think of it as technicaly as you were I think I was hoping more along the lines of cheap[img]/wwwthreads_images/icons/wink.gif[/img]!! So should I weld my shackles on the spring hangers toward the bumper or the other way around??
Thanx
Studly
post #10 of (permalink) Old 07-05-2001, 12:26 AM
Pooh-Bah
DougO's Avatar
Dont think Cheap, think Inexpensive ;-) haha and yes this was, total cost for all the metal for the spring hangers(1/4"), shackles(3/16"), and spring U-Bolt plates(3/8")plus square tube for the shacles was about $80. Mind you these were all 1 off's so of course the price was a lot higher then if I say had bought alot, the guy told me it would have knocked the price down to almost half per kit. It was all laser cut by a plasma cutter.
Oh yeah here is the URL to see basic shots I took tonight,
http://www.cartogra.com/home/viewown...wner=djo121371
Maybe someone else can make it clicky for me :-)
DougO is offline
