Re: power steering
if your going to 35's then do a yota conversion. Not hard on either if you have the ability to weld and fabricate brackets. Tracker is perfect for 31-33's and has a set turning radius that matches the sammi just right. toyota will flex and twist the frame if its not reinforced. Both cost right around 200 dollars i have noticed, or thats the stuff i can get. Brackets can get really expensive, but like i said fabricating your own is not that hard. Max
