4000rpm at 65? (tracker) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-22-2001, 08:56 PM
i have a 1990 tracker.
auto trans,1.6 8valve motor.
at 65mph i'm pulling 4,000 rpm.
is that normal?
or did someone put 5.13's in it?
post #2 of (permalink) Old 06-22-2001, 09:39 PM
Re: 4000rpm at 65? (tracker)
whoa 65 at 4000 rpms!!!! you are smokin on the highway!!! well what tire size do you run then I or you could use this chart if you know the ratios in your tranny (what the hell I will throw that in to! [img]/wwwthreads_images/icons/wink.gif[/img]!!!!)
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
72 fj40/crate 350/33's/discs
post #3 of (permalink) Old 06-22-2001, 09:42 PM
your ratios are all added in! (just change the difference in the Ring and pinions and compare) although you should not completely follow it cause it does not add things in like tire size and what-not!
P.S. that tire size is a wild guesse!!!!!!!!!!!
Thanx
Studly
post #4 of (permalink) Old 06-22-2001, 09:45 PM
i am running 205/75-15 tires
on stock rims.
is there a lockup converter in the 3 speed auto?
maybe that is why it is so high.
post #5 of (permalink) Old 06-22-2001, 09:58 PM
well if you go back (hate to be rude !) then you will see a post that was...auto tranny or something like that it should be noticeable though anywho we talked about what off-road.com said about those torque converters!
P.S. by the way your tires are 27.1 " O.D.
Thanx
Studly
post #6 of (permalink) Old 06-22-2001, 10:13 PM
My 91 5 spd spins just below that...... factor in slippage in the torque converter..... and that our little rigs aren't highway cars.
91 Suzuki Sidekick JX Softtop. K&N Filter, Modified Intake, Aurora 8.5 mm Plug Wires.
http://www.geocities.com/vtecsucks
post #7 of (permalink) Old 06-22-2001, 10:36 PM
My 2000 Tracker doesn't hit 4000 rpm's until 90 mph. Sounds like the tranny is slipping or someone changed the gears.
ROB
post #8 of (permalink) Old 06-23-2001, 02:28 PM
STUDLYBILLY,that is an excellent worksheet for calculating
rpms!
i'm probably going to 29" tires next to slow it down a little.i will be doing a 2" body lift so it should fit.
post #9 of (permalink) Old 06-23-2001, 02:41 PM
hey I would take credit for the craftmanship but I got it from off-road.com but I still got it! However it does not add things like tire weight so it is not exactly dead on target(unless you have that strong of an engine!) otherwise glad I could help!
P.s. if you want a copy of it I could send you one!
Thanx
Studly
post #10 of (permalink) Old 06-23-2001, 02:49 PM
I would drive it up to 60 mph, and make sure to note the torque converter lockup at 40-45 mph. You'll feel it shift from first-second, second-third, and then a light shift which is actually the torque converter locking up. My wife had a tracker a few years back, and 4000 rpm should be more like 75 mph, IMHO...
jason
loose_zuk is offline
