Pooh-Bah
Re: sidekick diffs on a zuk
Being done as you speak ;-) I just put my rear Kick axle under tonight, I have to pick up different perches though the ones I got I dont like, well, I like them, but just not for the kick rear. The Kick rear is 53" backing plate to backing plate compared to the sami 48" so what I'm doing is I have 2" backspace wheels for the front and 4" for the rear, so I'll be 1/2" off each side. Only problem with what I see you saying though is for your driveshaft. The Sidekick rear driveshaft as a slipyoke that goes into the back of the transfer, its not on the shaft itself, so you will have to find a replacement driveshaft. Tommorrow I am going to have my Yota shaft shortened either 2 or 3.5 inches to fit depending on which hole I use in the perches I get. The Sidekick rear also has a larger axle tube.
