-   -   compression test ?? (https://forums.off-road.com/suzuki-geo-all/75392-compression-test.html)
slowpoke 06-20-2001 02:37 PM
compression test ??
On my 92' I have compression readings per cylinder:
40
154
155
154
Is there a way to test if its the valve or ring(s) before i tear into it?
87 Samurai- 5.12's locked up,4340 front,hybrid rear,4.16's,P/S.,Toy. carb.,DT header, 33's, 2" exhaust and Durabak inside and out.
92 Samurai- Its next!!!
Zookin- a family affair
GODSZUK 06-20-2001 03:57 PM
Re: compression test ??
yes add oil to the cyl that has the low comp if it goes up its the rings if it doesn't its the valves
see ya quent
88 zuki,s/r,header,1600,locked in the rear and weber carb. with mitsu seats and 2"inch pipe
87 zuk spoa (new project)
IF GOD IS YOUR CO-PILOT SWAP SEATS
oldzuki 06-20-2001 06:30 PM
squirt oil in the cylinder-it pressure goes up suspect the
rings-if it stays pretty much the same suspect valves-don't
rule out a head gasket tho but usualy they go bad between
two cylinders causing 2 low readings--oldzuki
88 spoa samurai/weber/isky
97 sidekick sport
those that can samurai those that can't ?
**DONOTDELETE** 06-20-2001 07:19 PM
whoa if you get down to that much compression you must really be losing power..I think I will get one done just in'case!
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
72 fj40/crate 350/33's/discs
