F150 rims on zuk - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-06-2001, 08:21 PM Thread Starter
F150 rims on zuk
Hey guys,heard this will work?Im looking for something thats stock on another vehicle to transfer to my zuk to give "stock"backspacing a little.Will these rims do it and give a wider and more stable stance?
Thanks
1 cross plus
3 nails
4 given [img]/wwwthreads_images/icons/wink.gif[/img]
If only I wheeled as much as Im on this board[img]/wwwthreads_images/icons/crazy.gif[/img]
mudslide is offline
post #2 of (permalink) Old 06-06-2001, 08:29 PM
Re: F150 rims on zuk
I think it depends on what style rims you get , by the looks of some fords some wheels appear wider than others . the plain steel ones seem tucked closer in and the chrome and aluminums look further apart but I'm not sure about that . Heard that some dodge rims will fit zooks too.
mike
szabotage is offline
post #3 of (permalink) Old 06-06-2001, 08:37 PM
Mudslide,
I own an F-150 and also had the same brainstorm.... But, No Such Luck.... The backspacing and lug pattern fit okay but.... the center hole is too small to fit over the front locking hubs on the sammy. I have the Ford Factory Aluminum 15x8 and Ford Factory Steel 15 x 7 and same story on both units... I have also tried the chrome full size Dodge Factory mags for late model pickups & vans and same story... Center hole too small...
However, older Jeep wheels do fit. I would suggest test fitting any wheel before buying them or measure very ( especially the center hole diameter )carefully...
rodnee
Kool ZOOKS Rule
rodnee is offline
post #4 of (permalink) Old 06-06-2001, 08:42 PM
When i bought my 33's they came on some ford bronco stock steel wheels, they had the small center hole. 20 min with a grinder on each wheel and i could bolt them onto the zuk. the backspacking is way too much for a zuk though, thats why i put my 10's in the rear. These stock ford ones ate 8's
Anton is offline
post #5 of (permalink) Old 06-06-2001, 08:47 PM Thread Starter
So what was the final conclusion?I want to rid of the stock rims for a bigger print and wider stance preferably from the local "Auto Recycle"yard.
1 cross plus
3 nails
mudslide is offline
post #6 of (permalink) Old 06-06-2001, 09:17 PM
Mudslide,
I purchased a set of 15 x 8 aluminum AR wheels with a 3" backspacing, these wheels have a very large bead seating lip in excess of 3". So when I air down to 5 lbs the beads stay mounted. And I Beat on them.... No need for BEAD LOCKS!! They were a BEAR to mount tires on though had to use a lot of soap........ I am now running 32 X 11.5 Mud King tires and they're really great... Also, Summit Racing has white wagon type wheels with any backspacing and correct centerhole diameters for only about $25 each new!! I use these wheels as a set of spares with 30 X 10.5 tires them for on the highway.
rodnee
Kool ZOOKS Rule
rodnee is offline
post #7 of (permalink) Old 06-06-2001, 09:21 PM
Pep Boy's sells black ARE 15x8" rims with the D shade cut outs for $34.95 each.
Tim Martin
87' Samurai/1.6L/dual 40mm Mikunis/header/2" exhaust/MSD 6AL/5.5" SPOA/1" shackle lift/CJ-5/Sami springs/31" High-Tecs/roll cage, bumpers & pumpkin caps in progress...
zoomy4 is offline
post #8 of (permalink) Old 06-06-2001, 09:28 PM
if you use ford or dodge wheels make sure they came off
a 4x4 or they may have small holes and not fit over your
front hubs---oldzuki
88 spoa samurai/weber/isky
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
post #9 of (permalink) Old 06-06-2001, 11:15 PM
wheels off of jeep cj's will work
i know because i bought a set of 15X7 (sorry, dont know the backspacing) off an '85 jeep and put them on my zook.
Steve
'88 Suzuki Samurai
2" S/R 30x9.50 M/T's
[email protected]
Texas A&M Off-Road
FTAC of 2003
TexasA&MOffRoad is offline
post #10 of (permalink) Old 06-07-2001, 02:52 AM
I did this I actually have the rims in the shed right now. They are the chrome northland addition rims. That reminds me I need to sell them All I did was take them to a local machine shop and $20 later I had a perfect fit.
I used them when the Sammy was Stock.
LOCO
