Lets get it on!!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-27-2001, 04:32 PM
Lets get it on!!!
Me and my dad are about to go to a YOU PULL IT to get a rear bumper and I need to know what all parts I should look for to do a 4WD conversion? are there things I could use fro my 2WD axles or my t/case??
P.S. is this gonna be expensive???!!!
Thanx
Studly
92 Zuki/235's/1.6(soon)/Still Building
72 fj40/crate 350/33's/discs
post #2 of (permalink) Old 05-27-2001, 05:10 PM
Re: Lets get it on!!!
Do you need a front end hub to hub,to do your conv.i just heared my buddy talking about get read of one from his parts zuk.I live just out side of Lake City Fl.let me know ill get you a price for it if so.then you could drive up and get it and save the cost of shipping.
QuadZuki,87 spoa,33"wild countrys
post #3 of (permalink) Old 05-27-2001, 06:11 PM
Sounds pretty sweet! Hit me up on a price and if I think it is steep I will put in a bid!!
Thanx
Studly
post #4 of (permalink) Old 05-27-2001, 06:12 PM
P.S. I think I need the f. driveshaft t/case and the front axle!
Thanx
Studly
post #5 of (permalink) Old 05-27-2001, 09:42 PM
Brown29's Avatar
Stud, the easiest way to convert is to swap out the complete 4WD frontend from hub to hub. You will also need a 4WD tcase, a front driveshaft, and a tcase shifter and boot. It's easier if you can find a front diff and tcase with 14 mm flanges to match your existing driveshaft flanges. All 1989 and up and some 1988.5 models have the 14mm flanges. It didn't cost me too much to convert mine and it was well worth the effort.
[email protected]
Brown29 is offline
post #6 of (permalink) Old 05-27-2001, 09:49 PM
SWEET! But should I trust the junk-yard stuff??! I am worried about reliability!
How much would a junkyard charge for the parts?
P.S. HEY QUADZUKI I AM STILL INTERESTED YOUR FRIENDS STUFF THOUGH!
Thanx
Studly
post #7 of (permalink) Old 05-29-2001, 01:18 PM
Brown29's Avatar
I bought a used tcase with shifter & boot from one of the guys on this board. I used a spare front differential and axle housing I already had along with some of the 2wd front end components, to rebuild the front axle. Costed me $110 for the tcase and $40 for 2 spindles from a wrecking yard. (the 2wd spindles won't work for 4wd because the axle shafts won't fit through the opening) I also needed two lockout hubs because I had no spare hubs at $35 each used.
I replaced all the seals and felts too, since I was virtually rebuilding the front end and didn't want a $3 or $4 seal to cause me to have to tear it back down in another year or two. It probably cost me around $250 all together for the entire conversion. If you have to buy a whole frontend and a tcase it could easily cost quite a bit more, but would not require as much labor. I spent more time rebuilding the frontend and swapping out flanges on the driveshafts I already had than anything else.
Wrecking yard prices are likely to be higher than buying the tcase and front diff from an individual. Your best bet is to find a parts rig for $300-$500 with a good tcase and frontend if you can. You can always use the other spare parts eventually or even sell some to recoup your investment.
[email protected]
Brown29 is offline
post #8 of (permalink) Old 05-29-2001, 06:46 PM
Yeah but there has got to be a cheaper way of doing it!! I will just keep a sharp eye on stuff and probably try to get a parts rig!
Thanx
Studly
92 Zuki/235's/header/cherry bomb exhaust/Still Building
post #9 of (permalink) Old 05-29-2001, 07:55 PM
I have a T-Case, and Front end parts!
Rodney C
1985 CJ7,302 V8,T18,D20,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,Pony Carb...
CJ7JeepOffRoad is offline
post #10 of (permalink) Old 05-30-2001, 09:37 AM
Brown29's Avatar
Good luck coming up with all the parts needed for less than $250. I'm not saying it can't be done, because I see parts rigs for sale pretty cheap occasionally... but they're usually on the other side of the planet.
[email protected]
Brown29 is offline
