Stalling Problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-26-2001, 08:59 PM Thread Starter
Stalling Problem
This probelm with my Zuk is coming back again [img]/wwwthreads_images/icons/mad.gif[/img]
When your driving on the street, and coast to a red light or somthing, the truck always stalls. Even with the carb clean it does this.. and my idol was set at 2500 rpm, and it still does this. Ive been having these sortof probelms forever, has anyone else had similar problems?
Anton is offline
post #2 of (permalink) Old 05-27-2001, 10:54 AM
Cap34
Re: Stalling Problem
Mine was doing the same thing. I found a connector hanging loose on the firewall (kind of hidden behind some other wires). Turns out it went to the Three Way Solenoid Valve behind the carb. With the connector off, the EGR function is all messed up. Anyway, after fastening the connector, my problem disappeared.
post #3 of (permalink) Old 05-27-2001, 10:27 PM Thread Starter
Can you expain where i can find this connector? Hope it helps.
Anton is offline
post #4 of (permalink) Old 05-28-2001, 07:12 AM
Stall is fuel or spark loss condition.
Long term come and go likely fuel problem possible dirt in
gas tank or grimlin floating around in there.
Check fuel filter over pass side axle for clog if'in still
have one there. check carb float adjustment it's touchy.
I run hot idle of 780rpm never had Sam stall except for
time pull gas tank, install new home made gas sending unit
accidently put water into tank with gas it would stall I
restart run rough for min. and stall again.
