PONY CARB PROBLEM ANY SUGESTIONS! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-22-2001, 09:24 PM Thread Starter
dparker's Avatar
heres the deal runs like a top on level road but today i got it in some really weaked angles and going down step climb its floods out and dies had to put it to the floor just to get it running and then thats all i could do. take foot off the floor and it woul die had to get pulled level to get it running again does and body have any sugestions! if i turn the carb around the other way it stalls out at step inclines HELP HELP!!!.
RUN IN TO YOU LATER
dparker is offline
post #2 of (permalink) Old 05-22-2001, 09:40 PM
DannyL's Avatar
Re: PONY CARB PROBLEM ANY SUGESTIONS!
pressure regulator set at 1/2lbs will solve the problem.
Can also lower the float level below the center by a bit...
DannyL
Pony Express
http://www.partszuki.homestead.com
DannyL is offline
post #3 of (permalink) Old 05-22-2001, 09:45 PM Thread Starter
dparker's Avatar
thats what i was thinking about doing so does that take care of it all the stalling ?
RUN IN TO YOU LATER
dparker is offline
post #4 of (permalink) Old 05-23-2001, 05:34 AM
I run a Pony Yes the regulator will do the trick. I was in paragon this weekend, It never evan burped
off camber nose down you name it. set it to 1/2 lb on the trail and 2 or so on the road.
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
wildweasel is offline
post #5 of (permalink) Old 05-23-2001, 08:39 AM
87zuke's Avatar
Drifting from the original question but do you need to have a regulator with the pony? Thanks. Jim
http://sites.netscape.net/riodiusa
87zuke is offline
post #6 of (permalink) Old 05-23-2001, 08:43 AM Thread Starter
dparker's Avatar
i guess so if everbody else is running one but me
RUN IN TO YOU LATER
dparker is offline
post #7 of (permalink) Old 05-23-2001, 02:01 PM
For off-road use yes you should add one. For on-road use
no it's not really needed. what it does when turned down is
keeps too much fuel from entering the bowl causing the
pony to flood.Esp when going downhill.
Glenn
post #8 of (permalink) Old 05-23-2001, 10:43 PM Thread Starter
dparker's Avatar
hey danny where is the adjustment screw for the float located at.
thanks in advance , or does anybody else no?
RUN IN TO YOU LATER
dparker is offline
post #9 of (permalink) Old 05-24-2001, 05:59 AM
You need to bend the tab On the float just like any other carb. Just check through the sight glass
on the front of the carb, your fuel level should be in the center (On the dot).
Glenn
post #10 of (permalink) Old 05-24-2001, 07:59 AM Thread Starter
dparker's Avatar
im not wanting it in the center im wanting to take fuel away .but thanks did not no there wasnt a ajustment screw like every holley i have worked on .
RUN IN TO YOU LATER
dparker is offline
