Ujoint replacement and driveshaft spacer. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-18-2001, 11:31 PM Thread Starter
Nowhere's Avatar
Evening all. After lots of banging, a little bleading, some fileing here & there, some very hard wrenching, and some learning I have gotten my rear u joints off the driveshaft. SHWEEEW! These things are a pain in the a## if you don't know what you're doing.. I think the secret is to take those damn rubber dust boots off before the removal. I noticed something on the very last bearing removal; if you must twist the small piece (whatever the smaller section is called) so you can remove the thing easily. If you try to pull the thing while the joint is crooked or not tourqued (I'll have a pic) it is very hard to remove and will prob. dent the metal..
The upper joint on the rear driveshaft had one leg that was very rusty. Grease was optional in that one, I guess the seal broke or something. I bought some 10.00 greaseable joints from discount auto. The install process starts in the morning. I'm thinking on buying a vice to aid in the install process, just sorta press it into submisson vs hammer the @#$#$ out of it (really hurts ears). I'll have some pictures tmmrow afternoon. I'll prob replace the ones up front too, it has a good case of the vibes..
I ordered some stuff from petroworks, the vent tube, shifter fix, and 2 driveshaft spacers. One 1" and one 3/4" (1" for the front). As yall know I've got a 5" spoa kit on the zook. I did rotate the rear axle to compensate for the driveshaft angles. I unbolted the lower rear joint and tried to insert the 3/4" spacer. I've got about 3/4" before max compression! I dunno about the front end, but it looks like I'll not be able to use a d/s spacer in the rear. Anyone run into this like me? I am hopeing to see some performance with the vent tube <G>.
later..
got zook?
http://www.geocities.com/bik3r
29x10.5x15 SS TSL *SX*, Calmini Header, SPOA, Lights, Dupicolor!
Nowhere is offline
post #2 of (permalink) Old 05-19-2001, 10:21 AM
dparker's Avatar
Re: Ujoint replacement and driveshaft spacer.
thats what i running 3/4 spacers was all i was able to use too. as for the u jionts sounds like you worked up alot of wasted sweat next time use a blue wrench ! i had mine in and out in 45 minutes both of them.
RUN IN TO YOU LATER
dparker is offline
post #3 of (permalink) Old 05-19-2001, 10:24 AM
dparker's Avatar
o one more thing if you ever try that make sure you keep a good watch on those caps i have seen them explode out of there like a bullet the grease inside makes them do that
RUN IN TO YOU LATER
dparker is offline
post #4 of (permalink) Old 05-19-2001, 10:52 AM
I know, thoes U-joints are such a pain.. Even if you do know what your doing. I did mine with a hammer, a peice of pipe, a pair of vice grips, plyers, and a socket. It took me a few hours
Anton is offline
post #5 of (permalink) Old 05-19-2001, 11:33 AM
A vice makes it very easy to replace u-joints on a Sami,or any thing else .I have RR 4.5" spoa ,1.5 springs,1"longer frt shackles,2"longer rear shackles.I run 3/4" spacer on the rear,but I did not rotate the pinion angle.
Bluecrawler
post #6 of (permalink) Old 05-19-2001, 06:31 PM
WHoa, rotate teh rear axle? that help with the angle? sorry, but never heard of this. im gonna go with some yj springs here pretty soon, all ready got a guy nearby who has some. All i need is the "recepie" to make it safe. all the parts i will need and all that. thx
~Goot
post #7 of (permalink) Old 05-20-2001, 01:46 PM
when i changed out my rear u joint yesterday i broke a brand new #4 vise so your gonna need something a lil tougher
just thought i'd throw that in
87 samurai convertable
4 inches of lift
225 75 r15
2 inch exhaust catless
removable doors
coming soon:
lowrange cam
snorkel
on board air
post #8 of (permalink) Old 05-24-2001, 10:02 PM Thread Starter
Nowhere's Avatar
Check out the attached picture. You can see how the front end of the 3rd member in the rear has been raised up a little...
got zook?
Nowhere is offline
post #9 of (permalink) Old 05-25-2001, 11:40 AM
Ask Anton about making wood spacers for ur driveshaft (lol) He said he made one but I dunno how well it worked yet....... [shocked)
SPEED KILLS BUT YA GET THERE FASTER
KTM 500
post #10 of (permalink) Old 05-25-2001, 02:44 PM
zukiman
Hey Nowhere,
For how long have you had those shock boots on your driveshafts? I haven't been able to get more than about 300 miles out them on mine, they just explode from the high RPM's. They'd work fine on a trail-only vehicle, but at highway speeds I haven't been able to get one to last.
-- Geoff Beasley
