Need help with drain plug - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-17-2001, 05:13 PM Thread Starter
I was changin all the fluids in my sami today and when i got to the rearend the drain plug was messed up. Must have hit it on a rock or sumthin. Anyways no matter what i try it wont come out. Does any body have any suggestions.
Thanks for any help
Will
"It aint the wand its the magician"
"Keep the shiny side up"
Tread lightly
zukinut is offline
post #2 of (permalink) Old 05-17-2001, 05:44 PM
Re: Need help with drain plug
How about drilling a hole in it, and then run a very large sheet metal screw into it, then hook the screw with a pry bar to yank it out...? It's just an idea. Good luck!
Pillard
'87 Sami, 5.5" SpOA, 33" Pro-Comps, Snorkel, 8k winch, 23" buggy-leafs, etc, etc.
ppillard is offline
post #3 of (permalink) Old 05-17-2001, 06:24 PM
Buckyo7
a hammer does wonders!!
post #4 of (permalink) Old 05-17-2001, 06:35 PM
When I get a stuck bolt I put a pipe on the end of the socket wrench and use it as a pry bar. It's helped me a lot. You'd be amazed how just an extra foot on the end of a socket handle will give you that much more leverage. If you can't find a pipe just remove the rear diagonal drop bar on the rollbar and use that. I have a spare one I use just for this purpose.
Capn_Crunch is offline
post #5 of (permalink) Old 05-17-2001, 07:15 PM
use an impact gun and watch out for flyin fluids when it goes flyin off. messy but it will work
build it, break it, then build it better.
post #6 of (permalink) Old 05-17-2001, 08:58 PM
Same problem. Take a socket extension(6" or more), snap on a spark plug socket,jam the spark plug socket onto the ratchet handle, grab hold of the extension end and voila! Much more torque, all from the set of tools.
zukskywalker is offline
post #7 of (permalink) Old 05-18-2001, 04:07 PM Thread Starter
To much torque is the problem. I smashed it on a rock and messed up the head. Then when i tried to turn it, it rounded out. Tim @ NCO said to weld another bolt on it. Im gonna try that. Maybe Billy Bob can help me when i go up to his place on Monday. Cuz i cant weld worth a dern.
Will
Tread lightly
zukinut is offline
post #8 of (permalink) Old 05-18-2001, 05:54 PM
did you try a big pair of visegrips?? if you can get a grip with them a hammer tap on the handle should remove your plug. if not, the idea of welding a bolt head on is a good one--i've welded steel square tubing on before and used it as a handle to remove bolts! good luck!!
cueball
88 hd-top,1.3with weber, calmini cam,headers & 2" exhaust, jacobs ignition, 3" national spua , 4.16 tc gears, 88.5 5th gear,29x10.50 swamper tsl sx's
cueball is offline
post #9 of (permalink) Old 05-18-2001, 06:31 PM
if you dont get it by then, we will see what we can do man. if nuttin else, i got blue renches, solved everyting dat ails a feller.....[img]/wwwthreads_images/icons/tongue.gif[/img]
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #10 of (permalink) Old 05-19-2001, 12:02 AM
If you can raise the rear up a little bit, find a 12 point socket one size smaller and pound that on. Then try and turn it out. It has worked for me before. Good luck
-Ryan
'88 Sami. locked, Warned, lifted, geared. Two track mind
ZuksRule is offline
