RETREADS!!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-16-2001, 08:11 PM
RETREADS!!!
HAVE YALL SEEN THE PRICES ON RETREADS!! ANYWAY....WHACH YALL THINK OR HEARD ABOUT RETREADS?? I WAS THINKING OF RUNNING A 2 INCH SHACKLE LIFT WITH A 3 INCH BODY LIFT SO WHAT TIRE SIZE SHOULD I RUN AND NOT SQUEEZE IT UNDER MY SAMMY???
P.S. I WOULD ALSO BE RUNNING 5.12'S OUT OF A SIDEKICK!!!
Thanx
Studly
92 Zuki/235's/1.6(soon)/Still Building
72 fj40/crate 350/33's/discs
post #2 of (permalink) Old 05-16-2001, 08:28 PM
Re: RETREADS!!!
I had purchased the 30" at's and they were just as good as any other tire, the tread is similar to the BFG's. delivered to the door for only $200. as far as your lift goes, you will fit 31's with no problems but your gearing might be to much for the street though. Lance
87 Sami conv. Header 2" ex. 4-16 t-case, 5"lift,weber, rear lockrite,rancho's, and a very long wish list.
post #3 of (permalink) Old 05-16-2001, 08:48 PM
Re: RETREADS!!!
how about a set of retreads and highway driving? my rig is a daily driver and I get out most weekends. If I can SAFELY use retreads on the highway I think I'll go with them.
'85 SuziSkip
Slowly building a beast.
"If it's too hard or you're a pussy, give me a go at it"
http://www.newflavour.com
post #4 of (permalink) Old 05-16-2001, 09:15 PM
Re: RETREADS!!!
Where can I get these retread tires? Any web pages? Thanks:
Rodney C
Money Pit: 1985 CJ7 302 V8, T18, D20, D30, AMC20, SOA, Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End, And, And, And.........
CJ7JeepOffRoad is offline
post #5 of (permalink) Old 05-16-2001, 09:20 PM
Re: RETREADS!!!
http://www.hi-tec-retreading.com/siz...ices/index.htm
88 Sam 4.16,welded rear,235-75's on Ford truck wagon wheels, 4.5 spoa,5k quick mount Ramsey
post #6 of (permalink) Old 05-16-2001, 09:27 PM
Re: RETREADS!!!
I run the 31" MT High Tech retreads and think they are great. 5.12's would be too low of a gear unless you were running 33's. With the lift combination you mentioned you would only get approximately 4" of lift and could barely fit 31's underneath. They would definitely rub offroad. Also, with 31's and 5.12's you would only get up to 55mph and be tach'n you engine out at 4500rpm.
A lot of people do not like the body lift because of the added stress it puts on the body and it is a PITA to install. If you have to go this route, go with a 2" body lift and try some Add-A-Leaf springs. It will give you a stiffer ride though.
Personally, I would go with a 5.5" SPOA lift if you can weld or find someone else to do it for you. Then if you add the 1" shackle lift you could fit 33's underneath and use the 5.12's to correct for the larger tires. There are other things that have to be addressed such as steering, brake lines and drive shafts when you start getting up above 4" of lift if you want your rig to remain safe and drivable. I have some moderate bump steer and the pucker factor is pretty high when you hit a pothole or large bump at 55mph!
Welcome to the never-ending spiral… I bought my Samurai only 9 months ago to drive and tinker around with. Now look at me!
Tim Martin
87' Samurai/1.6L/dual 40mm Mikunis/header/2" exhaust/MSD 6AL/5.5" SPOA/1" shackle lift/CJ-5/Sami springs/31" High-Tecs/roll cage, bumpers & pumpkin caps in progress...
zoomy4 is offline
post #7 of (permalink) Old 05-17-2001, 12:23 AM
Re: RETREADS!!!
I'm running 32" tires with 5:12 gears and a GRS 1 and would like it lower but I never drive it on the road just in rocks
post #8 of (permalink) Old 05-17-2001, 08:10 PM
Re: RETREADS!!!
YEAH I KNEW TRYING TO GO CHEAP WOULD NOT WORK, BUT WHAT THE HECK IT WAS WERTH THE SHOT!! THE WEBSITE I FOUND THE RETREADS IN WAS THE HI-TEC LISTED ABOVE OR JUST FOR THE HECK OF IT
WWW.MALLMERCHANT.COM/RETREADS
I JUST HOPE I COME UP WITH A GOOD SOLUTION TO MY GOING CHEAP AND WANTING A GOOD OUT COME!!
Thanx
Studly
