jacking the samy - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-11-2001, 04:19 AM
jacking the samy
Hi finally I will start my spoa tomorrow morning.
I have the brake lines the spacers and the spring perches.
The only problem I forsee is how will I lift the samy high enough to remove and reinstall the axles and tires. I have this friend that has got am Hi-lift jack but there is no place to use it in my samy.
Any ideas ????
Rui Alberto Sá Freitas
Livramento de Cima
1º Impasse da estrada do garajau n.º 9 e 11
9125-066 Caniço
Ilha da Madeira
PORTUGAL
post #2 of (permalink) Old 05-11-2001, 04:52 AM
Re: jacking the samy
rui-when i did mine i disconnected driveshafts shackles at
bumpers-ubolts jacked up car put it on jackstands and rolled
axles out with the tires still on do only front or rear at
one time then switch ends--oldzuki
88 spoa samurai/weber/isky
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
post #3 of (permalink) Old 05-11-2001, 05:01 AM
Also where should I suport the car ?? near the spring mounting points ? Is it save like that ? can I remove the 2 axles savely ?
Thanks in advance
Livramento de Cima
9125-066 Caniço
Ilha da Madeira
PORTUGAL
post #4 of (permalink) Old 05-11-2001, 05:05 AM
I have tought about it like that, but how do you slide it back in ?? there won't be room for the axle with tires under the springs...
Livramento de Cima
9125-066 Caniço
Ilha da Madeira
PORTUGAL
post #5 of (permalink) Old 05-11-2001, 07:56 AM
remove the tires from the axles man. makes working a lot easier. much more room. when i did my spoa, i put my jack stands under the frame at the solid mount for the springs. plenty safe. when it came time to position the pinions(note, axles were loosely bolted in), i jacked it up, put my jack stands under the axles so it had the full weight of the truck on the axles. set the angles and finished up, now its high enough to put tires n wheels back on
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #6 of (permalink) Old 05-11-2001, 09:12 AM
Thanks things do look much easier now. Let's see how they come up.
another question
I have the RRO wrap around perches that will be welded directly to the old perches. So is it necessary to take the oil out of the axles ?? I don't have to set the angles ? Do I ?? (note I have got 2" longer shackles at front and 1" longer at the rear)
Livramento de Cima
9125-066 Caniço
Ilha da Madeira
PORTUGAL
post #7 of (permalink) Old 05-11-2001, 10:27 AM
Brown29's Avatar
You won't have to drain your diff to weld the perches. I think the RRO perches are designed to retain the stock castor, but I'm sure Glenn Wakefield would be glad to answer your questions specific to the perches directly if you email him.
Brown29 is offline
post #8 of (permalink) Old 05-11-2001, 10:52 PM
Nowhere's Avatar
I think this picture will help...
got zook?
http://www.geocities.com/bik3r
Nowhere is offline
post #9 of (permalink) Old 05-11-2001, 10:53 PM
Nowhere's Avatar
nother..
got zook?
Nowhere is offline
