Taller 5th?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-14-2001, 06:30 PM
Taller 5th??
Is the conversion of the 92's fifth gear(which is .795)to the taller 89's fifth gear(.865) a hard thing to do?
thanx
Studly
92/235's/Still Building!
post #2 of (permalink) Old 04-15-2001, 11:29 AM
4xRonin
Re: Taller 5th??
Most folks just change the entire tranny. The 5th gear ratio was changed in 88 I believe.
Scott Whitmore
"Share your knowledge. It's a way to achieve immortality." Dalai Lama
post #3 of (permalink) Old 04-15-2001, 03:11 PM
Re: Taller 5th??
I agree with Scott. Changing the whole tranny will be much easier than just the one gear.
Quite likely, it might also be cheaper to pick up a whole tranny than just buy the one gear new from Suzuki (or other).
http://www.rocky-road.com
post #4 of (permalink) Old 04-15-2001, 05:03 PM
Re: Taller 5th??
FYI,
In the NA market
86-88 Samurais have the 0.795 fifth gear
88.5-95 Samurais have the 0.865 fifth gear
You'll actually need two gears-the 5th gear and the 5th counter gear. Both are quite easy to get to once you have the tranny out and pulled apart.
Like the others, what I suggest is to find a tranny with the fifth you want, rebuild the sucker (easy if you've go access to a press), and bolt it in.
1988.5 Zuk: OD Green Paint, ARB Bumper, OME Lift, 1.6 engine, ISKY DP Cam, Weber Carb, CF II Clutch, 4.16 Transfer, etc.
gi_zuk is offline
post #5 of (permalink) Old 04-15-2001, 05:46 PM
Re: Taller 5th??
I got an extra transmission when I bought my Zuk. Is there any way of telling which year or overdrive it is by looking at it? DG.
post #6 of (permalink) Old 04-15-2001, 07:03 PM
Re: Taller 5th??
as a rule of thumb (in my opinion), look at the drain plugs on it. if its a bolt style (that screws in the tranny), its a older one with taller 5th, if it is a flush plug that has a 3/8 square in it to remove it, it is most likely a later model. THIS IS NOT A PROMISE, BASED ON MY EXPERIENCES this has proved true.
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #7 of (permalink) Old 04-16-2001, 12:12 AM
Brown29's Avatar
Re: Taller 5th??
What Billy Bob said about the drainplug type holds true on all I've ever seen too.
Brown29 is offline
post #8 of (permalink) Old 04-16-2001, 04:04 AM
Re: Taller 5th??
I believe Billy Bob is correct on his ID definition. I have 6 Samurai transmissions-the ones with the 0.795 fifth have the big 1" hex nut whereas the one 0.865 fifth have the 3/8" adapter. From what I recall, these filler/drain plugs are not interchangeable either.
gi_zuk is offline
post #9 of (permalink) Old 04-18-2001, 11:29 AM
Re: Taller 5th??
Billy Bob:
Which tranny should I use with 31" tires? The early 88 (0.795) or the later 88 (0.865)?
Thanks!
[email protected]
wvn8v is offline
post #10 of (permalink) Old 04-18-2001, 03:41 PM
Re: Taller 5th??
I edited this BTW..
Just to throw a wrench in the ID, My 90 trans is identical to my 87's As to the drain plugs. 90 has the lower 5th too. I am going to go back to my 87 trans after a rebuild so I have the taller 5th now I have 4.62's..
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
wildweasel is offline
