K601 Weber Jetting - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-09-2001, 09:37 PM Thread Starter
CrowHorse's Avatar
K601 Weber Jetting
Does anyone know what the "baseline" jetting for the K601 Weber? I'm curious how my jetting compares to an out of the box Weber.... Thanks....
idle jets 50/50
main jets 125/120
air jets 160/155
emulsion tubes F50/50
All Good Medicine,
Crow
CrowHorse is offline
post #2 of (permalink) Old 04-10-2001, 03:27 AM
Re: K601 Weber Jetting
The second numbers look pretty close to the out of the box open air filter model. I believe the stock air cleaner adapter model is 105/120. FYI, I never changed the air jets or emulusion tubes just the main jets to 135/170 and it seems to be on the money for a mildly modified 1600.
1988.5 Zuk: OD Green Paint, ARB Bumper, OME Lift, 1.6 engine, ISKY DP Cam, Weber Carb, CF II Clutch, 4.16 Transfer, etc.
gi_zuk is offline
post #3 of (permalink) Old 04-10-2001, 03:52 AM Thread Starter
CrowHorse's Avatar
I know I need to go larger on my idle jets.....
All Good Medicine,
Crow
post #4 of (permalink) Old 04-10-2001, 05:07 AM
Why do you need to go larger on your idle jets? How is the engine idling for you to come to this conclusion. I'm curious because I'm having no problems with the original size and I've got a 1600.
gi_zuk is offline
post #5 of (permalink) Old 04-11-2001, 09:31 PM Thread Starter
CrowHorse's Avatar
According to everything I've read, if the idle adjustment screw is more than 2 1/2 turns out from bottom to achieve a "best idle", the idle jets are too small and require larger ones.
I've got the Weber on my 1600 as well. The Weber is an older one, myself being the 3rd owner. I believe it was purchased originally by a zooker from Colorado. I'm not sure if he tinkered with it to compensate for the altitude. I periodicaly experience a lean miss at idle. Increasing a size or two might correct this.....
All Good Medicine,
Crow
post #6 of (permalink) Old 04-12-2001, 04:37 PM
So where do you find jets for the weber.
Loco
post #7 of (permalink) Old 04-12-2001, 06:40 PM
i buy my jets for webers from pierce manifolds they have
a $20 min order to order by phone with a credit card if i
remember correctly. my orders are usualy big enough thats
no problem for me but if you need also order a rebuild kit
or let me know and i can add your stuff to my next order or
let me know what you need jet size wise i might trade some
jets with you if i have on hand what you need--oldzuki
88 spoa samurai/weber/isky
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
post #8 of (permalink) Old 04-12-2001, 08:34 PM
oldzuki im running a32/36 601 w k/n filter i have a 1600 header and 2' ex any sug on what jet size runs best
thanks quent
88 zuki,s/r,header,1600,locked in the rear and weber carb. with mitsu seats and 2"inch pipe
87 zuk spoa (new project)
IF GOD IS YOUR CO-PILOT SWAP SEATS
GODSZUK is offline
post #9 of (permalink) Old 04-12-2001, 10:16 PM
crow & GODSZUK--i like crows basic setup-but stock k601
come with 120/155 mains-crow is running larger main on
primary 125/120 and sometimes geting lean- i would switch
crow to 130/150 or 135/160 on mains and leave all else the
same-oldzuki
97 sidekick sport
oldzuki is offline
post #10 of (permalink) Old 04-13-2001, 01:17 PM
Thanks alot not sure what ould be the best setup. But I am getting a better Idea as this post goes on. I has a 1600 with a mid range cam, header, the performance weber(larger jets), and a high power ignition system. Any suggestions I know you will have to play with them a little but a starting point is always helpful.
LOCO
