When good transmissions go bad - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-09-2001, 12:41 PM Thread Starter
Well, i'm starting to get a vibration in all gears and my transmission started leaking oil from somewhere on top. As I slow down to around 5 mph and hold the shift lever in neutral it shakes quite a bit now. The rubber mount is still good. My t-case has poly mounts and it has no vibration through the shifter. Is there something else other than the transmission that could cause this vibration? Is this how they typically go out?
-Ryan Primel
Suzuki, Jeep, Chevy, Ford, who cares, as long as you're out on the trails wheelin'.
ZuksRule is offline
post #2 of (permalink) Old 04-09-2001, 12:53 PM
mike shannon
Re: When good transmissions go bad
it sound like you just have some bad u joints more than likly it is on the short shaft to the t case. most of the time when the tranny goes out it starts growling and making nasty noises. pull your top drive shaft out put in a set of u joints and a new seal in the back of the tranny and you will more than likly be fine. later mike
88.5ht,two87s,88.5 spoa,33X12.50,5.12 f&r,rock cage,4.16 T case
post #3 of (permalink) Old 04-09-2001, 01:03 PM Thread Starter
Thanks for the reply Mike. Does the transmissin need to be removed to change the rear seal? And also, does anyone know where I can buy NON-greasable u joints other than the dealership? Thanks guys
-Ryan Primel
ZuksRule is offline
post #4 of (permalink) Old 04-09-2001, 02:00 PM
YOZR U CAN REPLACE THE REAR SEAL WITH THE TRANNY STILL IN ABOUT THE N/G JOINTS I DONT HAVE A CLUE I LIKE THE GREASERS MYSELF LATER QUENT
88 zuki,s/r,header,1600,locked in the rear and weber carb. with mitsu seats and 2"inch pipe
87 zuk spoa (new project)
IF GOD IS YOUR CO-PILOT SWAP SEATS
GODSZUK is offline
post #5 of (permalink) Old 04-09-2001, 02:02 PM
OOPS sorry i yelled i use this computer to do invovices at the tranny shop quent
GODSZUK is offline
post #6 of (permalink) Old 04-09-2001, 03:59 PM
4xRonin
Ryan, I get my spicer u-joints from NAPA. They have no grease fitting. HTH
Scott Whitmore
"Share your knowledge. It's a way to achieve immortality." Dalai Lama
