HELP!! engine stalls.... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-05-2001, 04:35 PM Thread Starter
The Sami has developed a new problem...
Once the engine warms up it will stall when it's under load. It will idle fine but when I engage the clutch and put it in gear then release the clutch it will stall out. The only way I can get the car to run is if I push the RPMs up high and keep them there while I disengage the clutch. The trany is noisy and I suspect that this might be part of the problem but I'm not sure. It's definately not the gas or junk in the tank becasue I just had it drained and cleaned.
Any help would be appreciated.
Capn_Crunch is offline
post #2 of (permalink) Old 04-05-2001, 05:46 PM
Re: engine stalls....
I would try a new fuel filter, especially after having disturbed all the junk in you fuel tank by cleaning it.
-Farther
Farther is offline
post #3 of (permalink) Old 04-05-2001, 06:26 PM Thread Starter
Did the new fuel filter too...
post #4 of (permalink) Old 04-05-2001, 07:02 PM
If you changed the filter at the same time as cleaning the tank, your new filter may have plugged up too.
-Farther
Farther is offline
post #5 of (permalink) Old 04-05-2001, 07:23 PM Thread Starter
I did the filter after the tank. I'll take it off and see if I can blow it out.
post #6 of (permalink) Old 04-06-2001, 12:37 AM Thread Starter
anyone?
post #7 of (permalink) Old 04-06-2001, 12:58 AM
What kind of card do you have? had the same issue with my Weber. Turned out to be the filter on the carb an some sensor just needed to be cleaned. Haven't had problem since.
post #8 of (permalink) Old 04-06-2001, 01:09 AM
Me speak bad english type worse
LOCO
post #9 of (permalink) Old 04-06-2001, 02:38 PM Thread Starter
stock carb.
post #10 of (permalink) Old 04-06-2001, 03:30 PM
Have no help then. I'm getting pretty good with the weber though.
Sorry,
Damien
