question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-06-2001, 10:12 AM
question
i changed the oil in everything i could, the engine transfercase, trany, diffs, but what about the steering box? does it need to be changed if so how do i do it? also the birfields? how do i gease them up? thanks
always looking for samurai parts
post #2 of (permalink) Old 02-06-2001, 11:56 AM
Brown29's Avatar
Re: question
The steering box doesn't have to be greased as regular maintenance. If you're going to repack the birfields you need check your steering knuckle grease seals and felts before you start. If you're losing grease there I'd replace them at the same time. You'll need to take the front hubs, wheel bearings, and the spindle off to repack the birfields. That's a good time to check the upper and lower kingpin bearings as well since you're already there. The upper one is usually the first to wear out.
Brown29 is offline
post #3 of (permalink) Old 02-06-2001, 12:46 PM
Re: question
to repack the birfeilds, the easiest way is to remove the caliper (2, 17mm bolts) then remove the disc, then remove the 4m 14mm bolts holding everything onto the steering knuckle, now you can pull it all out, pack it with grease, and install. Otherwise you could remove the hub, the 2 big nuts, spindle, then pull the axle out.
<font color=red>Anton</font color=red>
<font color=blue>[b]Locked And Lifted![b][img]/wwwthreads_images/icons/smile.gif[/img]</font color=blue>
Anton is offline
