question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-02-2001, 08:46 PM
question
im gonna remove my pistons hone out the cylinders add new rings, do a valve job and maybe change out rod bearings if needed just a quick rebuild got a week off and need to do something my rig is using a quart of oil a day and after engine warms up it begins smoking but dont smoke while cold
any ideas? any problems with the quicky rebuild it just has to last me until i get a rebuilt motor ordered in about 6 months to a year any info appreciated
always looking for samurai parts
post #2 of (permalink) Old 02-02-2001, 10:08 PM
ZukiBrother's Avatar
Re: question
they will run along time like that. i drove mine 45 miles to work everyday and the motor lasted 6 months, i had to add a quart for every trip i made. it still ran when i pulled it out, just got to expensive putting that much oil in it, but it ran good. i wouldn't necisarly try to do a quick rebuild, just run it till it dies.
1990 samurai spoa
soon to have 2.8 and c4 auto
33" thornbirds
ZukiBrother is offline
post #3 of (permalink) Old 02-02-2001, 10:25 PM
Re: question
well it only smokes after the motor warms up. could it be i just need to change the valve guides? could the valve lashing needing adjustment cause los of power? thanks
post #4 of (permalink) Old 02-03-2001, 07:33 AM
Re: question
have you run a compression test?
Hey, Jeeps do taste like Chicken!
post #5 of (permalink) Old 02-03-2001, 05:31 PM
Re: question
yeah i did but think my meter is wrong it read abound 185 give or take on all cylinders
post #6 of (permalink) Old 02-03-2001, 05:36 PM
Re: question
IMHO,
If you do a valve job and nothing to the lower end, ie, rings. Itís a guarantee that whatís left of the piston rings will go bye, bye. As posted above, What is your compression AFTER it warms up? After you take the first compression reading, squirt some motor oil into each cylinder as you retest them. If the compression reading goes up, that will tell you that your problem is rings. If not, then itís valves.
If your using that much oil, and not laying a new oil surface for the road department, then it must be rings. Maybe try some STP. *GriNs*
<font color=red>Beat It To Fit . . </font color=red><font color=green>. . Paint It To Match</font color=green> [img]/wwwthreads_images/icons/tongue.gif[/img]
Bobcat is offline
post #7 of (permalink) Old 02-04-2001, 01:37 AM
Re: question
i might also add my fuel milage is still pretty good im getting about 30 mpg
post #8 of (permalink) Old 02-04-2001, 12:49 PM
Re: question
bubba-if your compression guage is right you have great
compression- till you pull it down you won't know for sure
but i would suspect a bad oil ring and/or valve stem seals
while your down check it all out and fix as needed
oldzuki
88 spoa samurai/weber/
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
