Anti-Theft Measures - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-31-2001, 01:10 PM
ronin
Anti-Theft Measures
While I was working on making my doors removable, I started thinking about how to protect from theft. My neighbor recently had his chevy fullsize swiped while he was out boating one day and it has kinda bothered me ever since. Just out of curiosity, what do you guys do to keep your rigs safe and in the same parking spot you left it in?
post #2 of (permalink) Old 01-31-2001, 01:16 PM
Re: Anti-Theft Measures
I am planning on puting in a hidden engine kill switch somewhere under my dashboard, as soon as the weather gets a little warmer. The more mods I do to my Zuk the more paranoid I get about someone stealing it while i'm at work.
-Ryan Primel
'88 zuk, 1.6L, spoa, drop-links, grs1, 32's, Locked & Warned
ZuksRule is offline
post #3 of (permalink) Old 01-31-2001, 01:40 PM
When I lived in S. Africa they had a huge problem with auto theft...one of the most common anti-theft devices whas a gear lock....this locked the shifter into one position...usualy revese. I'll bet you could make one out of the right materials and a long necked lock commonly found at walmart etc...
That is what I'll be putting on my zook when I have to start worring about it walking off on me.
Reuben
post #4 of (permalink) Old 01-31-2001, 02:15 PM
87zuke's Avatar
I knew a guy that used one of those long u-shaped bike locks and locked the clutch and brake pedals together. Jim
http://sites.netscape.net/riodiusa
87zuke is offline
post #5 of (permalink) Old 01-31-2001, 02:16 PM
DannyL's Avatar
Another option is to remove a wheel & tire and take it with you.
LOL
DannyL
Pony Express
Updated site 17 Jan 2001
http://www.partszuki.homestead.com
DannyL is offline
post #6 of (permalink) Old 01-31-2001, 02:32 PM
Zuk Jr.'s Avatar
The Anti-Theft thing I do when my doors are off is to put the t-case in neutral position, most people that try to steel a car/truck try to get away fast, well this will stump them and buy ya a few extra mins. I know it works, one day I did that and put it in 1st gear and I couldn't go anywhere! I forgot that the t-case was moved to the "N" spot and felt stupid! It took me a few mins to figure out what was holding me from moving! [img]/wwwthreads_images/icons/wink.gif[/img] I even let my friend use my Zuk to get some food for a party we had, and he came in the house about 5min later and said that he broke my Zuk, I forgot to tell him to put the t-case back in the 2wd spot! Works for me!
<font color=blue>Brian</font color=blue> [img]/wwwthreads_images/icons/cool.gif[/img] <font color=blue>THE ULTIMATE ZUK</font color=blue>
Zuk Jr. is offline
post #7 of (permalink) Old 01-31-2001, 03:27 PM
Brown29's Avatar
That's a pretty good deterrent, Brian. A lot of thugs ain't rocket scientists anyway. That AND an underdash kill switch combined could probably keep me from stealing it long enough to round up a posse.
Brown29 is offline
post #8 of (permalink) Old 01-31-2001, 03:49 PM
I use a piece of steel cable that is coated with plastic and has loop s on the ends i loop one end around my brake and clutch together and the other end around one of my steering wheel spokes and lock the end at the steering wheel with a Master Lock this is not fool proof but the last thing a thief wants is to have to spend time.
post #9 of (permalink) Old 01-31-2001, 03:59 PM
zukiman
You can kill two birds with one stone when making a clutch pedal over-ride plug. As you know, when you try to start the engine without the clutch pedal depressed, nothing happens; the clutch has to be in. Off-road it's often nice to be able to crawl on the starter motor for a couple seconds, so an over-ride switch is nice.
In the wiring up by the pedals, you'll find one coming from the clutch to the ignition, with a plug in the middle. All you have to do is take the plug out and solder the two wires together on the pedal side. This gives you the clutch over-ride so you can crawl with the starter motor, and it also gives you an ignition kill plug. When you park, just remember to take the plug with you and you have one more deterrant to theft.
Combine that with putting the t-case in neutral, and it'd take a while to figure out how to get the truck to move. Additionally, if you have the Spidertrax Full-Floater rear axle you can unlock the rear hubs and the thief would probably never figure it out.
--Geoff Beasley
post #10 of (permalink) Old 01-31-2001, 04:03 PM
CrowHorse's Avatar
Tie in an on/off switch in the clutch circuit and do the same for the ignition. You can elliminate the fuseable link and replace with an inline fuse that can be removed. I doubt a thief would find this when used with the other measures. You've probably have seen those infomercials on that "club" type of lock for the brake pedal. Looks to be pretty good and better than the "Club".
Welding tabs for a lock on the shifter and the t-case shifter while in the reverse/neutral or low range position.
I've also heard of using some creative wiring to use a coil to zap a would be thief if it wasn't disarmed.
Then there is the shotgun shell under the seat trick, but I won't go there........
Only kidding.......
All Good Medicine,
Crow
CrowHorse is offline
