More Power - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-29-2001, 02:58 PM
More Power
Just another question totry and improve the 1300 power output, does anybody know if the 1300 head with 1600 valves and a low-mid range cam would be worth the effort and money. I already have the thorley header and weber carb. Thanks for the input, Lance
87 Sami conv. Header 2" ex. 4-16 t-case, 4"lift,weber, rear lockrite,rancho's, and a very long wish list.
post #2 of (permalink) Old 01-29-2001, 03:40 PM
Re: More Power
Lance, from my experience, putting larger valves tends to move the rpm range of an engine higher a bit. I have never been satisfied with the modest power gains vs. the Pain & $ to do it.
There is No Substitute for cubic inches (or centimeters) Lance.
HTH,
OILBURNER [email protected]
OILBURNER is offline
post #3 of (permalink) Old 01-29-2001, 05:40 PM
dparker's Avatar
Re: More Power
there is no replacement for displacement
RUN IN TO YOU LATER
dparker is offline
post #4 of (permalink) Old 01-29-2001, 06:00 PM
Re: More Power
I think your better off leaving your 1300 head alone, I read somewhere in glenn wakefields 1600 swap that he used the valves and lifters from the 1300 head in his 1600 head because he had a problem with the 1600 lifters breaking when using an isky torquer. The 1300 valves and lifters appear to be stronger
szabotage is offline
post #5 of (permalink) Old 01-30-2001, 04:47 PM
Alfie
Re: More Power
OK if I can butt in on this post, what about hi comp pistons, blueprinting, balancing and the forementioned cam ?
Do y'all think this would give the little Zookie a boost, or is cubes still the only way up?
Interested,
alfie
post #6 of (permalink) Old 01-30-2001, 05:48 PM
Re: More Power
i just finished installing a calmini cam in my 1300-already had a weber, 2" free-flow exhaust w/free-flow cat & dynomax,
jacobs ignition, 4.16 t/c gears. at the same time i installed a 88.5 tranny with it's lower 5th gear and am very pleased with results-now i can run 70 mph with no problem-finally!! that's with 29x10.50 swamper tsl's which are very heavy
cueball
cueball is offline
post #7 of (permalink) Old 02-01-2001, 06:00 AM
Re: More Power
Err, not to sound thick but won't the 1600 head just bolt on to the 13?? Would be cheaper and easier right?
88 Vitara JLX, Koni's, King Coils 2.5" over, MT's, JayCar ign boost, Motivator Header, 2" sys, Mikuni 28/30.
Money = Power = Fun & angry spousal unit
post #8 of (permalink) Old 02-01-2001, 03:20 PM
Re: More Power
mee's tinks that a 1.6 head will go right on a 1.3, but you wont have provisions for a mechanical fuel pump on the 1.3 then. unless you have a fuelinjected zuk with a tank pump, it can be a problem. you would have to get a electric pump to give you go juice from the gas tank.
BiLLy bOb
Do unto others as you want done to you!
If you pack it in, pack it out!
Billy Bob is offline
post #9 of (permalink) Old 02-01-2001, 09:07 PM
Re: More Power
Now that's wierd, because my Vitara runs the 16 8v and there's provision for a mechanical fuel pump, it's got a blanking plate on it at the mo' as it's always had a electric pump by the tank, now I know this is an add on as the wiring to it's real scruffy, but hey it works, a mate is an auto sparky but we never have time to do the rewire, still it works.
d
post #10 of (permalink) Old 02-02-2001, 08:31 AM
pugrocker
Re: More Power
cueball-
what is the idle like on the calmini cam - rough or smooth? I was considering getting their cam for my 1.6L but I do not want it to idle all wacky.....thanks
pug
