new user needs help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-25-2001, 05:12 PM Thread Starter
i'm new to the forum but not to zukin. just installed a calmini cam in my 1.3 (no instructions-it was in another 1.3 i bought for the 88.5 tranny) set it up per haynes manual for establishing tdc and it was 180 off! camshaft sprocket had mark painted 180 degrees opposite small hole with mark stamped across it. reset rockers & clocked distributor but fuel pump not pumping-it did fire & run briefly with gas poured in carb. any ideas? thanks for any help!
cueball is offline
post #2 of (permalink) Old 01-25-2001, 07:36 PM
zooky's Avatar
Re: new user needs help!
is the fuel pump push rod installed?
zooky is offline
post #3 of (permalink) Old 01-25-2001, 07:44 PM Thread Starter
yes the rod is installed, however it may be binding-i'll pull pump off & check. my main concern is the timing being opposite the haynes manual-though every thing seems right as far as valve opening/closing sequence and firing order etc. i thought that maybe the calmini cam had different positioning for the index mark?? thanks for the reply!
cueball
88 samurai h-top weber,headers,free-flow exhaust,4.16 tc,3" national spua, swamper sx tsl, jacobs -hopefully still runs!!!
cueball is offline
post #4 of (permalink) Old 01-25-2001, 09:09 PM
the haynes manual has an error in it! key on crank pulley
goes up at tdc cam gear mark goes down they point toward
each other-oldzuki
88 spoa samurai/weber/
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
post #5 of (permalink) Old 01-25-2001, 10:52 PM Thread Starter
thanks for the input-i thought as much-editor should be forced to drive a stock sami for all time! still could not get fuel pump to work-even tried my spare, no luck. hooked up my boat gas tank and it fired right up & ran great!! maybe i'll just put electric pump on & not worry about it.
thanks again
cueball
cueball is offline
