throttle sticking on weber....????? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-04-2001, 02:19 PM
pugrocker
Once my engine warms up - my weber throttle sticks and the engines revs up between 1500 and 2200 rpms (at idle - no pushing of the gas peddle) and I have to rev the engine to kick it back down do idle speed. What is the deal? How can I fix this and is this a common problem for Webers?
Another question - Crowhorse told me that a fuel regulator helps smooth out the Weber's idle and just make it run better in general. When I spoke with Calmini (who sold me the Weber) they said that this is not needed - especially because I have their 1.6L swap kit which gives the correct fuel pressure with the supplied fuel pump. Do I need to add a regulator and if I do at what pressures should I run it (between 1.5-3.5 psi as shown in the instruction manual)?
help me please.......
thanks,
pug
post #2 of (permalink) Old 01-04-2001, 05:05 PM
Brown29's Avatar
Re: throttle sticking on weber....?????
You just need to add a small spring that puts tension on the throttle linkage to make it return to idle position when you take your foot off the pedal. I took one off of a stock carb.
Brown29 is offline
post #3 of (permalink) Old 01-04-2001, 08:00 PM
run an xtra throttle spring or change to a little stronger
one webers come with too weaka return spring. i run a fuel
regulator on my weber 1/2 to 1 lb off road usualy 3 1/2 lb
on the road. my weber book say 4lb max. hope this helps
oldzuki
88 spoa samurai/weber/
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
