Added Tach, now gauges are screwed up! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-25-2000, 06:50 PM
TheProton
Hi All,
I have a non-JX 88.5 Suzuki Samurai (square dash vents). I wanted to add a Tach, so I purchased an instrument cluster from a 88.5 JX model at a Junkyard. I swapped the two clusters, and the Tach, Speedo, idiot lights, and turn indicators all work fine.
The Problem is that the Fuel and Temp gauges now read way off. As soon as I turn on the Sammy the Fuel guage moves to full, irregardless of actual fuel level. The temp guage stays in the cold area until the engine starts to warm, and then it shoots way off the hot end of the scale. Since my engine hasn't melted, this is also inaccurate.
I Love my new Tach, but need the other guages. I tried swapping the Fuel/Temp guage from the original cluster, but they don't fit at all. The cluster is not returnable.
Any help would be greatly appreciated!!
post #2 of (permalink) Old 11-25-2000, 07:19 PM
Re: Added Tach, now gauges are screwed up!
i have not seen this happen before try checking for
corrosion in plugs on new dash then make sure of grounds
for guages. my 88 is a jx and came with a tach but have
swapped dashes on others with no problems-but i use
dielectric grease on reassembly on plug-ins. oldzuki
88 spoa samurai
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
post #3 of (permalink) Old 11-25-2000, 08:26 PM
dont know where you are but if you decide to get rid of that cluster let me know email me at [email protected]
famous last words "BET YOU CAN'T DO THIS"
post #4 of (permalink) Old 11-25-2000, 11:47 PM
I put a 88.5 instrument cluster into a 92 and had to rewire the instument cluster. The printed circuit is not the same on both and the gauges were the most different. Trace the printed circuit back to the plug-ins and compare the two clusters. Also make sure that the gauges have the same polarity as the old ones.
FRANKENZUKI,10 foot tall and bullet proof!
-Shawn- is offline
post #5 of (permalink) Old 11-26-2000, 12:09 AM
I have the same problem.I changed nothing,driving down the road one day and the temp and fuel gauge both peaked out.any info would be greaty appreciated.
post #6 of (permalink) Old 11-26-2000, 06:11 PM
Sounds like a bad connection that grounds both of those circuits jointly... Get a wiring diagram and look for the ground that completes both of those circuits. The conversion should work properly if all was hooked up correctly... I have heard that the harnesses and clusters are different but you should be swapping the entire harness & dash as a unit and simply plugging it in. The tach feed is factory installed in all firewall harnesses...
Later, Rodnee
Caught by the "ZOOKIE OBSESSION" bug. ZOOKIE ZOOKIE ZOOKIE ZOOK.......
rodnee is offline
post #7 of (permalink) Old 11-26-2000, 07:08 PM
I thought you could just swap them out... I took one out of an 88 to sell on ebay. And advertised as such I hope its just a connection problem because they are already bidding on the one I have for sale...
Lifes tough...even tougher if you're stupid
post #8 of (permalink) Old 11-26-2000, 07:53 PM
icarusZOOK:
I believe your information is correct. I installed a tach cluster in my 86. It was a plug in & go; everything works.
-Farther
Farther is offline
post #9 of (permalink) Old 11-27-2000, 09:41 AM
Brown29's Avatar
The JX cluster with the tach is wired the same as the others (at least for the carbureted Zuks). I've swapped the round vent dash type JX for a round vent non-JX type before with no problems. A bad ground connection will cause both the fuel and temperature gauge to behave as you described. I've never been able to find a square dash pod with a tach, but would like to find one for a '93 fuel injected model if anyone has one.
Brown29 is offline
post #10 of (permalink) Old 11-28-2000, 05:01 PM
What happen to the Ebay listing. I went out there to look for it and I couldn't find it.
bucwheat
88 1/2 Zuk
4 inch SPOA, Rancho 5000s
2 inch over Shackles
1 inch body lift
Full Camo
Coyotes beware
