Sloppy Steering Question? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-22-2000, 10:13 AM Thread Starter
Zuk Jr.'s Avatar
My Zuk has some sloppy steering and it is getting bad! What can I do to fix the problem? I run SPOA with 2" longer then stock shackles, and a "Z" bar, also have a Rancho steering stablizer. The rubber fitting where the "Z" Bar is are bad (right at the pitman arm & steering knuckle), not as tight as they use to be, I can move the Z bar with no problem, it is really easy to move! My friends Zuk has the same Z bar on it and his is hard to move, it stays in the same place if you move it. That could be the only problem I can think of. Any help would be great! Thanks
Brian [img]/wwwthreads_images/icons/cool.gif[/img]
Zuk Jr. is offline
post #2 of (permalink) Old 11-22-2000, 10:44 AM
pugrocker
Re: Sloppy Steering Question?
All I can say is that I had a Z-Bar with 1" lift shackles and my steering was sloppy also. I have a total of 4" of lift and added the Calmini Linkage steering and now my steering is tighter(I also have P/S). The only drawback is that the idler arm from the Calmini Steering hangs down kind-of low (a bit below the springs - I am SpUA). Anyway you look at it - a lift will throw off your steering especially if you add longer shackles. You can also consider using the steel caster shims that RRO sells to help tighten things up a little.
Another thing - In my own opinion I think that the add-on steering stabilizer does not really do much to help with steering problems.......all that it does is hide shimmy and shake from unbalanced wheels or a screwed front end. The stock stabilizer serves a little more of a rwal function.
pug
post #3 of (permalink) Old 11-22-2000, 02:10 PM Thread Starter
Zuk Jr.'s Avatar
Hey thanks Pug, I'll have to look into the RRO thing! I also kinda knew about the stabilizer, I just had to get one because I can't find anyone around here to balance my 36" TSL's and the stabilizer does its job, so to speek. Thanks for your help!
Zuk Jr. is offline
