Vibration & Shake ?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-19-2000, 07:57 PM Thread Starter
CrowHorse's Avatar
If the brake problems weren't enough, my 87 has now developed a low speed shake/vibration, only rearing it's ugly head at app. 5 mph. At high speeds there is no vibration. It seems like the transmission is shaking but I'm not sure as of yet if it is the culprit as it was rebuilt several months ago. I also have new motor mounts. A cursory inspection of the u-joints proved fruitless ( I was hoping it was one). Has anyone had a similar experience? I'm not sure where to even look at this point. Any ideas would be greatly appreciated....... Thanks
All Good Medicine,
Crow
CrowHorse is offline
post #2 of (permalink) Old 11-19-2000, 08:54 PM
Re: Vibration & Shake ??
Just guessing.If the tranny mount has ever been oil soaked ,from a leaky real seal , it can sure soften them up.Check tcase mounts.
U joints can feel tight mounted , but be fairly sloppy off the truck.Check tranny to motor bolts.
CrowHoss , if you get all your problems cured , & that little basturd gives you ANY more trouble, please smack it w/a BFH for me !
That's all from this corner
post #3 of (permalink) Old 11-19-2000, 09:19 PM Thread Starter
CrowHorse's Avatar
The rear mount is dry - no oil. I will check the tranny mounting bolts tomorrow and maybe swap in a another intermediate shaft to try to narrow it down. I'm so thankful that I have another zook for wheels.
BFH...I've used it already.
At least I now have new motor mounts (HD Hawk mounts). Pretty soon I'll have replaced everything on it.
All Good Medicine,
Crow
post #4 of (permalink) Old 11-20-2000, 05:02 AM
I had a low speed squeek and vibration, turned out it was the driveshaft from the trans to tcase. One of the u-joints
froze. It then chewed up the trans mount... Just push up on the trans that will tell you if the mount is good.
I will try this moening to get the @#$% seatbelts off again. about ready to take the torch to it and send you part of the floor too....
Glenn Loud
87' Zuke Spoa, 31's, 4.16 tcase, Camo,Header,2"exhuast, Cam.
Locked both ends, 8klb winch, Snorkel -Wildweasel2
NE4WI- club
wildweasel is offline
post #5 of (permalink) Old 11-20-2000, 04:46 PM Thread Starter
CrowHorse's Avatar
Glenn,
No rush. I have my hands full with all sorts of anomolies in my 87.
I've discovered the culprit! A frozen u-joint on the intermediate shaft was causing all the mayhem. It was a good lesson in that you really can't accurately check u-joints unless they are off the truck. I change to my spare driveshaft and the vibration is gone. I'll put new u-joints in the one that came out and swap them again. Any suggestions on u-joint brand? I've used the ones from PEP Boys with success, but I've started to check them before leaving the store and they must have had a bad run of them. The bearing cups didn't spin smoothly, like it might have been contaminated with foriegn particles. Ones that didn't have this worked well....so far.
Thanks for all the help!
All Good Medicine,
Crow
post #6 of (permalink) Old 11-20-2000, 09:48 PM
Crowhorse , I've had good luck w/ the $7 pep joints.........til now . Just today I discovered 1 w/only 12k on it (Toy) , had some play.
Don't know about LI but in Burque there's a driveline shop that sells Spicers for $23 w/ free install.
That's what I'm doing from now on.
