Help... Stubborn Third Member - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-16-2000, 09:03 AM
1988 Samurai
I tackled my pinion bearing problem last night. I took the axles out removed the drive sharft and got to the third member. The third member was not sealed with a gasket as it was suppose to but rather with liquid gasket. The liquid gasket from what I can figure is acting like a seal/glue. I tried tapping it out but it won't budge. I when so far at to try to rid a slide hammer to it but that didn't work.
Does anyone have any suggestions on how I can get it off? I am so close!!!
post #2 of (permalink) Old 11-16-2000, 09:28 AM
Re: Help... Stubborn Third Member
you are almost there , the third member does'nt have a g
asket they come from the factory with silicone gaulk(RTV). once the bolts are removed take a sharp screwdriver or chisle and place it in the seam between the case and third member. rap it with a hammer a couple of time to seperate the two you may have to work your way around the casing. you will reseal it again for assembly with more RTV good luck
were not here for a long time were here for a good time
post #3 of (permalink) Old 11-16-2000, 10:31 AM
put a jack under it and jack it up slowly
Rui Freitas
Rui Alberto Sá Freitas
Livramento de Cima
1º Impasse da estrada do garajau n.º 9 e 11
9125-066 Caniço
Ilha da Madeira
PORTUGAL
post #4 of (permalink) Old 11-16-2000, 09:48 PM
rui had the best idea. I build transmissions and 3rd members for a living, I never wedge housing apart with chisels or screwdrivers. I used a 5lb shop hammer to knock my sammi 3rd member loose but I like Rui's suggestion better. Maybe, put a bind on it with a jack then hit it with a hammer.
