Engine Shutting off - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-26-2000, 02:35 PM
Engine Shutting off
Aye ya'll, maybe you can help me out.
My 91 sammy is EFI, and it has been sputtering and doing strange things lately.
When I rev the motor up (acellerating) and i hit a certain RPMS it begins to click (the ECU, under right hand dash), engine sputters and the electrical system flickers on and off. The engine doesn't turn off, but it is like it dies for a split second and is on again. This also happens when I hit about 50 miles an hour. I have to drive it under that or not rev the engine up too high for this not to happen. Anyone have any ideas?
I have just replaced the spark plugs and cables last night, hoping maybeit would do something (they needed to be replaced anyway), and sure my motor runs a hell of a lot better, but it still does the dying thing.
Is it a feul problem?
Also, there is a ground wire going to the electronic ignition moutning bracket under the hood. It is bolted on to the bracket and it is a dark color like black. It is kinda burnt through, does anyone knwo what this is for?
-Mike
_____________
RAGEx2 - Mike Egli
[email protected]
Office- 415-444-7171
Cellular- 707-318-6503
1991 Suzuki Samarai
1995 Jeep Cherokee
post #2 of (permalink) Old 09-26-2000, 03:39 PM
Re: Engine Shutting off
Is it your coil ground?Anything burnt needs replacing anyway[img]/wwwthreads_images/icons/crazy.gif[/img]
Criminals prefer unarmed victims!Al Gore wants your firearms!Defend 2nd Ammendment
mudslide is offline
post #3 of (permalink) Old 09-26-2000, 03:57 PM
It does not seem to be the coil ground because it goes back into the shrink wrapped wiring harness that runs along the firewall. I can follow it without rippig the whole damn thing to shreds. Got any other ideas what could be causing the problem? Someone said it could have something to do with my fuelpump or fuel filter, that the engine might not be getting enough fuel. . . could that be it?
How do I check that?
-Mike
_____________
RAGEx2 - Mike Egli
[email protected]
phone-(707)318-6503
1991 Suzuki Samurai
1995 Jeep Cherokee
1984 Toyota Pickup
post #4 of (permalink) Old 09-26-2000, 04:11 PM
Definitly could be that.Im not real experienced with FI,but yea check your fuel pump pretty easy but check your manual,its step by step.I know on carb models you take the hose that goes into the carb off,then turn the engine over.If you have steady streams of gas coming out,its working.If it just trickles,pumps bad.But it might not work like that on FI.
mudslide is offline
post #5 of (permalink) Old 09-26-2000, 05:17 PM
My 90 is fuel injected and it did the same thing. Check the alternator cables, the alternator itself and ALL electrical connections. My problem was caused from the reverse light switch on the tranny. The 2 wires were touching the body or the transmission. Ya, i know it sounds stupid but when i unhooked the harness to them on the firewall the problem went away.
If you have any other questions about the FI let me know.
Oh ya, after flipping 3 times to the right hand side, endoeing once and ending up laying on the drivers side it was still running. Aint never seen a carb'd engine do that.
WIll
zukinut is offline
