Toyota Driveshafts - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-24-2000, 05:17 PM
Toyota Driveshafts
I am in the process of a SPOA and a missing link setup, being an ex Toyota guy and having Toy buds I was thinking that an early Toy front driveline might work perfectly on the rear of my Sammy. Has anyone done this, seems the CV joint would be ideal due to the driveline angle. I think I can redrill the holes in the rear pinion to work but the one on the transfer case will not work. Has anyone replaced the transfer pinion with one from a Toyota is it the same spline and size, I have a Toy one and it looks similar but I would like to avoid pulling mine if it's a no go. One last thing the length looks perfect does anyone know how much length you need on the drivelines to keep them from pulling out under extreme flex,i.e. Missing link. Thanks in advance... Luigi
1986 Samuraii
Shackles
4:1 trasfer case
More mods on the way just waiting for the lottery board to call
post #2 of (permalink) Old 09-24-2000, 07:39 PM
Re: Toyota Driveshafts
Check out this article- http://www.izook.com/tech/toyotadriv...stallation.htm
88.5 Samurai is offline
post #3 of (permalink) Old 09-24-2000, 08:32 PM
they are not the same spline -toy -to samri- are you trying to upgrade ? i'll check into it - http://www.highangledriveline.prodigybiz.com
post #4 of (permalink) Old 09-24-2000, 10:37 PM
hi 88.5 and jesse,thanks for the info.i will add it to my manual for future reference,ranger rick
THANK GOD FOR VETERANS AND SUZUKIS-BOTH KEEP YOU FREE. FOUNDER;INDIANA SUZUKI EMERGENCY RESPONSE TEAM
rangerrick is offline
post #5 of (permalink) Old 09-25-2000, 12:22 AM
Dont know about the front driveshaft but the rear driveshaft is a direct match up to the bolt holes on and 88.5 and newer ZUKs match perfectly on both the t-case and rear pinion flange. However, the bit problem is that you will have to have the flange inner diameter widened, or the toyota flange trimmed a few thousands of an inch to match, up. On both sides. You may have to do some trimming on the inner flanges of the yota so that the pinion nut and t-case pin nuts dont hit. You will need to look for a 89 or newer yota rear, usually out of a xtra cab 4x4 truck, but they all look like they would work. Help give a try!!
"Happiness is a Belt Fed Weapon!"
lav25 is offline
post #6 of (permalink) Old 09-25-2000, 09:53 PM
I have an 86 so I think it will not work.
1986 Samuraii
Shackles
4:1 trasfer case
SPOA in progress
Missing links on the way
