removing doors - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-22-2000, 12:10 AM Thread Starter
removing doors
ok, i got an impact driver today...
gonna remove the doors by way of unscrewing them...
im not gonna cut the hinges cause i dont like cutting parts up...
i know ya'll say its easy, but im still not going to do it...
ok, so how do i go about removing the screws?
i plan on replacing them with regular bolts so that i can remove them later on with a socket... i use the number 2 bit, right?
any advice (excpet for cutting hinges) will be appreciated
thanks
Steve
'88 Suzuki Samurai
2" S/R 30x9.50 M/T's
[email protected]
Texas A&M Off-Road
FTAC of 2003
TexasA&MOffRoad is offline
post #2 of (permalink) Old 09-22-2000, 05:16 AM
zooky's Avatar
Re: removing doors
I say CUT THE HINGES!!!...but if you insist, use a #3 bit, and use a scribe to break the paint around the screw head first
zooky is offline
post #3 of (permalink) Old 09-22-2000, 05:26 AM
Re: removing doors
i agree cut the hinges-but if you don't get studs and cap
nuts to fit them that way you can pull the doors and put
cap nuts on studs sticking out get xtra caps cause you will
lose some use locktite on threads living in texas you may
go weeks w/o running doors but most people are on & off with
their doors and cut hinges are fast for switching.
88 spoa samurai
97 sidekick sport
those that can samurai those that can't ?
oldzuki is offline
post #4 of (permalink) Old 09-22-2000, 06:04 AM
Re: removing doors
when you get one that won't come off get a big pair of visegrips, clean the paint off clamp them on while
pushing in and stick a big screwdriver into the jaws to give them a twist.
Glenn Loud
87' Zuke Spoa, 31's, 4.16 tcase, Camo,Header,2"exhuast, Cam.
Locked both ends, 8klb winch, Snorkel -Wildweasel2
NE4WI- club
wildweasel is offline
post #5 of (permalink) Old 09-22-2000, 06:58 AM
Re: removing doors
Dear Aggie,
Please listen to these guys and cut the hinges. but if you dont want to modify the original hinges go to a wrecking yard and get some so that your orig. ones will be just that original. after you get them if you need some one to cut them box em up and send em to me, email me if you need help.
Gig em Ags
Skeetshoooter
post #6 of (permalink) Old 09-22-2000, 07:51 AM
Yankee Tim's Avatar
Re: removing doors
Hey Steve,
I can understand not wanting to screw around with your parts, and I was reluctant at first. But having the hinges cut is pretty nice. I don't notice any difference other than a quick 1.5 mins to doorless freedom. If you do it, you won't regret it. Junk food for thought...
Yankee Tim is offline
post #7 of (permalink) Old 09-22-2000, 08:56 AM
Re: removing doors
You should have bought 2 impact drives, I broke 2 impact drives and one bit when I removed my doors and had to replaced the bolts.
It's hard to take them but it sure look nice.
Rui Freitas
Rui Alberto Sá Freitas
Livramento de Cima
1º Impasse da estrada do garajau n.º 9 e 11
9125 Caniço
Ilha da Madeira
PORTUGAL
post #8 of (permalink) Old 09-22-2000, 08:58 AM
Re: removing doors
Actually, it is not uncommon to not want to cut the door hinges. We actually carry a bolt kit for the doors for folks like that. Then all you need is a wrench and a couple minutes every time the doors come on or off.
You are not alone in your thinking though.
Hardcore Suzuki products for hardcore enthusiasts.
http://www.rocky-road.com
post #9 of (permalink) Old 09-22-2000, 09:34 AM
Re: removing doors--Use Fire!
Another way to get the body bolts out of a ZUK is to go to Lowes and get a little hand held butane torch for about $10, fire it up and heat up the bolt heads till they start smoking then just use a screwdriver to remove the bolts. The heat melts the bolt locktite used by the factory and makes getting them out much easier and less damaging.
"Happiness is a Belt Fed Weapon!"
lav25 is offline
post #10 of (permalink) Old 09-22-2000, 11:11 AM
zooky's Avatar
I removed the hinges on my half-doors to clean them up and now I regret it, it took forever to get the screws to stay tight and they kept coming out of alignment so the door would not close right. Cutting the hinge does not weaken them, when the door is closed they sit in the door frame, which supports the door, not the hinges.
zooky is offline
