HELP !! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-20-2000, 09:44 PM
HELP !!
Hi all I have a question about the timing belt on my sammy. Ok heres what happened to me in a nut shell. I just finished putting in the new Petro Works Clutch, And went out to test it. It works REALLY WELL... broke my drive line&u-joint where it connects to the rear 3rd member.
When that happened my motor revved really high guessing to high, any way I stripped the teeth off of the timing belt.
I have replaced the timing belt and retimed it. but now it makes a funny noise when its running. almost sounds like a vibrating sound, it gets louder when u rev the engine. you can hardly hear it when its idling. What did I do??? Possably bent valve?? Thanks in advance for any and all help.
Rick
post #2 of (permalink) Old 09-21-2000, 06:00 AM
Re: HELP !!
Are you sure the noise is coming from the engine? Not the transmission or the Motormounts?
Glenn Loud
87' Zuke Spoa, 31's, 4.16 tcase, Camo,Header,2"exhuast, Cam.
Locked both ends, 8klb winch, Snorkel -Wildweasel2
NE4WI- club
wildweasel is offline
post #3 of (permalink) Old 09-21-2000, 10:26 AM
Re: HELP !!
quiteshur you didn't bend a valve,i've had my motor wound up to 8grand on several occasions with no problems. does the vibration go away if the motor is under aload? are you 100% shur it is timed axactley right on and not a tooth or two off? timing cover on correctly...not rubbing on a belt.
just questions
dan
87'samurai 88'samurai,quittin work just to play, rocks and boulders are my fortay.
post #4 of (permalink) Old 09-22-2000, 01:59 PM
lojones's Avatar
Re: HELP !!
If nothing is broken, it sounds like the timing is off to me.
Lonny - Redmond, WA
87' Stomper, SOA, Missing Links, Z-bar Eliminator, 5.125RP, 4.16TC, lockers, bead locks and 33" Boggers
www.mystomper.com
lojones is offline
post #5 of (permalink) Old 09-22-2000, 08:45 PM
Re: HELP !!
Thanks everyone for the replies. I went back thru everything, double checked the timing it was on. I even pulled the oil pan and everything looked ok there. So I put everthing back together, and it still made the funny noise.
I took it on a little drive and when I got back home the noise is gone.... I guess I'll just run it and see if it comes back. Thanks again everyone for your help.
Rick
post #6 of (permalink) Old 09-30-2000, 10:01 PM
Re: HELP !!
collapsed lifter that pumped back up when you ran it?
