Carb rebuild???? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-07-2000, 10:16 AM
STONECOLD
Carb rebuild????
It took me a month and a half to get the clutch cable and alternator i ordered. My samurai ran fine before. Now it runs fine at idle, but give it a little gas and it tries to die. If it doesnt die it boggs down and has no power. THe only thing i can think of is the carb since it was running fine before. Any one got any suggestions? I also need some tips on rebuilding the carb. Is there a link on the net somewhere with diagrams for rebuilding the carb because my sucky Haynes manual doesnt help at all?
thanks
sc
post #2 of (permalink) Old 09-07-2000, 01:02 PM
Re: Carb rebuild????
Well my advice would be to do as little as possible to it... Open the two 12mm bolts to the float chamber
and squirt a cans worth of the nastiest carb cleaner you can find. then try it and see how it is. really there
is so little you can do to these carbs and so much you can screw up. I have rebuilt carbs for years but these
little stinkers are a pain. evan a professionally remanufactured carb I got was bad. It was replaced under
warrenty but I haven't swapped it back as the old on I stuck on it running great.
Glenn Loud
87' Zuke Spoa, 31's, 4.16 tcase, Camo,Header,2"exhuast, Cam.
Locked both ends, 8klb winch, Snorkel -Wildweasel2
NE4WI- club
wildweasel is offline
post #3 of (permalink) Old 09-07-2000, 09:49 PM
The mixture screw??????
all the way in = closed/lean???
all the way out = open/rich??
How many 360degree turns from all the in does the carb come set at when factory? I have just received a rebuilt one this morning but it appears as though it is running very rich. I can smell fuel (more than usual) coming from the exhaust, especially when changing gears.
'85 SuziSkip
1.6 22R off it's rocker
"If it's too hard or you're a pussy, give me a go at it"
post #4 of (permalink) Old 09-07-2000, 09:58 PM
STONECOLD i've got a good carb if interested. I am in the process of putting a Toyota carb on mine, wanted to lose all the vaccuum b.s. and elect. hookups. Now have less vac. lines than fingers.......lol Should have it running again this weekend provided work does not interfer, @#$%#$^ pager's!
slowpoke is offline
post #5 of (permalink) Old 09-08-2000, 12:08 PM
How well dose your carb work?? would you being willing to trade somthing for it? how much were you thinking of saleing it for?
http://www.delphi.com/n/mb/at.asp?we...roll_x5_8a.jpg
post #6 of (permalink) Old 09-08-2000, 02:50 PM
Check your O2 sensor it may not be plugged in or good. It is on the exhuast manifold. If the computer isn't
getting anything from it it goes "open Circuit" which means Rich. The Idle mixture adjust will only take care of
the idle mixture.
Glenn Loud
NE4WI- club
post #7 of (permalink) Old 09-08-2000, 09:04 PM
STONECOLD
Well i fixed it. Drained all the gas, then put in 1 gal. of super and a can of Chemguard in the tank. Cleared up in about 5 minutes. I would floor it so it would bog down that gave it a good dose of the Chemguard. Cleared up in no time. Even took her for a spin without any trouble.
post #8 of (permalink) Old 09-09-2000, 06:37 AM
Glad to hear that you got it. these carbs work okay until the smallest thing goes wrong then they are a bear to
troubleshoot.
Glenn Loud
NE4WI- club
